Notices
Old 06-29-2007, 04:21 PM   #1
PatInTheHat's Avatar
Removing Case from Transreflective.
So I believe im going to go ahead and order one of these but I have one nagging concern. It seems very likely that in order to do my install I will need to remove the housing that the LCD comes in. I realize this voids the warranty but are there any other problems/concerns I might encounter by doing this. This is my first Car PC (although I am a fairly tech handy person) and I might be getting a bit over my head here and it would suck to toss away $700 by making a stupid mistake.
PatInTheHat is offline   Reply With Quote
Old 06-29-2007, 04:55 PM   #2
FreeDrive Creator
CdRsKuLL's Avatar
just make sure you dont damage the ribbon connections, just take your time and dont force anything. I took mine apart and moulded it in no probs.. good luck :-)
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 06-29-2007, 05:19 PM   #3
erie's Avatar
Also remember that the TS panel for the trans is slighlty thicker that the non-trans TS so be sure not to over tighten the screws that hold the LCD panel. Other than that is just like a standard liliput.
06 Galaxy Gray Si #0308
CarPc Progress -
10%---------50%---------100%
-[XXXXXXXXXXXXXXXXXXXXXX]-
erie is offline   Reply With Quote
Old 06-29-2007, 06:22 PM   #4
How much thicker are we talking?
Old 06-29-2007, 06:26 PM   #5
FreeDrive Creator
CdRsKuLL's Avatar
the touchscreen floats above the panel by a couple of mm's, on mine it was all aligned up after by using little white doublesided pads. I just moulded in the front part, then rebuilt the screen back in and even screwed the back case on
97 Toyota Tacoma You gotta See This. NEW UPDATE with 100+ pics on 7-4-03 cproaudio Show off your project 97 09-18-2006 02:56 PM
FS: Casetronic C138 Mini-ITX Case, Black 120W rinroe Classified Archive 8 08-15-2006 03:26 PM
Buy Case Or Build Case setite Newbie 7 07-19-2006 07:31 PM
is frodo compatible with voice software? nappyjim FrodoPlayer 23 11-01-2004 05:50 PM
Mounting the case TheFly General Hardware Discussion 8 05-05-2002 04:11 PM
