The MP3car.com Store
Thread Tools Display Modes
Old 06-29-2007, 03:21 PM   #1
PatInTheHat's Avatar
My Photos: (0)
Removing Case from Transreflective.
So I believe im going to go ahead and order one of these but I have one nagging concern. It seems very likely that in order to do my install I will need to remove the housing that the LCD comes in. I realize this voids the warranty but are there any other problems/concerns I might encounter by doing this. This is my first Car PC (although I am a fairly tech handy person) and I might be getting a bit over my head here and it would suck to toss away $700 by making a stupid mistake.
PatInTheHat is offline   Reply With Quote
Sponsored Links
Old 06-29-2007, 03:55 PM   #2
FreeDrive Creator
CdRsKuLL's CarPC Specs
CdRsKuLL's Avatar
Vehicle: Ferrari 360 (nearly)
My Photos: (5)
just make sure you dont damage the ribbon connections, just take your time and dont force anything. I took mine apart and moulded it in no probs.. good luck :-)
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 06-29-2007, 04:19 PM   #3
erie's CarPC Specs
erie's Avatar
Vehicle: 2006 Honda Civic Si
My Photos: (3)
Also remember that the TS panel for the trans is slighlty thicker that the non-trans TS so be sure not to over tighten the screws that hold the LCD panel. Other than that is just like a standard liliput.
06 Galaxy Gray Si #0308
CarPc Progress -
10%---------50%---------100%
-[XXXXXXXXXXXXXXXXXXXXXX]-
erie is offline   Reply With Quote
Old 06-29-2007, 05:22 PM   #4
My Photos: (0)
How much thicker are we talking?
Old 06-29-2007, 05:26 PM   #5
FreeDrive Creator
CdRsKuLL's Avatar
My Photos: (5)
the touchscreen floats above the panel by a couple of mm's, on mine it was all aligned up after by using little white doublesided pads. I just moulded in the front part, then rebuilt the screen back in and even screwed the back case on
Sponsored Links
Trackbacks are Off
97 Toyota Tacoma You gotta See This. NEW UPDATE with 100+ pics on 7-4-03 cproaudio Show off your project 97 09-18-2006 01:56 PM
FS: Casetronic C138 Mini-ITX Case, Black 120W rinroe Classified Archive 8 08-15-2006 02:26 PM
Buy Case Or Build Case setite Newbie 7 07-19-2006 06:31 PM
is frodo compatible with voice software? nappyjim FrodoPlayer 23 11-01-2004 04:50 PM
Mounting the case TheFly General Hardware Discussion 8 05-05-2002 03:11 PM
Sponsored Links
Ad Management by RedTyger
