Notices
Old 07-09-2007, 04:43 PM   #1
Lilliput problems
I just bought an 8" lilliput monitor from the store here and im having trouble with it. When i first got it i was using it to install windows but after the first restart it stopped working. Then later on worked until i got to the winxp load screen.
Now however the monitor turns on and all the buttons turn blue but if i plug it into the vga i get no video but i can use the touchscreen and if i have video plugged in and then plug the power in i get a blinking red power light. I have tried hooking it up to my power supply and with the supplied ac-dc power. The Ac powersupply gives 12.47V and the cpu powersupply gives 12.43V and both give the same results.
Thanks for any help
Virac is offline   Reply With Quote
Old 07-09-2007, 04:57 PM   #2
that is strange. Good luck, hopefully someone can chime in who has one. I didn't get mine yet. So are you unable to program any of the codes listed on this forum? (codes that control how it powers on, etc.)
do you have a spare power supply atx that you can test it on inside?
Snortonnorton is offline   Reply With Quote
Old 07-09-2007, 05:41 PM   #3
I have tried all the different methods with 588998 and nothing happens. The thing that gets me is the monitor was working and now its not and that if the vga is on i get a red blinking power light.
Old 07-09-2007, 09:45 PM   #4
I cant get any video to work on this. I have tried the vga and the composite. i cant even get to the menu after the monitor is turned on. the only way i know its on is the buttons turn blue and the red power light is on. anyone have any suggestions to what may help? could maybe the lcd ribbon of fallen out of its seating?
Old 07-10-2007, 09:53 AM   #5
Mine is doing the same thing, I believe the monitor is dead, I would try reseting the ribbon cables inside, I haven't tried yet because I didn't have a screwdriver.
voldaran is offline   Reply With Quote
Old 07-10-2007, 10:07 AM   #6
i would try that but i dont want to void my warranty. if i knew for absolute sure that was the only problem i would have no issue opening up the monitor but im just affraid of somthing else being wrong as well.
Old 07-10-2007, 01:38 PM   #7
Yeah, I might wave goodbye with my warranty (if you want to call it a warranty, bought on ebay) and have a go at the insides later tonight. I'll keep you posted on the results, We have the exact same problem.
Also, I've read some strange things happen when you get the Rez and Hz wrong on the monitor, I don't think this is the cause, but worth looking into, resetting the rez to something like 1024x768.
Hopefully it will be that simple!
Let me know what you do with your's.
V.
Old 07-10-2007, 01:41 PM   #8
I just got an rma from the store here. its a damn sexy monitor and I wanna be sure it works before i void my warranty.
EPIA M10000 + Lilliput 619 problems Calipso General Hardware Discussion 4 04-04-2007 09:42 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Lilliput and ribbon cable problems Udonboy LCD/Display 21 11-08-2004 08:24 PM
got new lilliput but problems..... bobthebaker LCD/Display 23 10-11-2004 01:39 AM
lilliput touchscreen problems dominic Input Devices 1 01-14-2004 07:50 PM
