Notices
Old 07-30-2007, 02:32 AM   #16
portabuddy's Avatar
lol i foam covered mine and coated it in hard plastic two tart epoxy...
2006 civic Si Goin' big
But im going with a 10.2" screen, for this i had to cut the whole navi section out ans start over..., i got a lot of sanding to do...
A good tio is to get a good HIGHT BUILD PRIMER and spray a light spatery coat of black paint, then can the surface to find where your low points are then use glazing putty(VERY FINE finishing putty) to fill in the low spots then sand again and prime then sand some more... here is a preview of my headache...
Life Dosn't come with a reset button, if it did you might as well turn the game off.
portabuddy is offline   Reply With Quote
Old 07-30-2007, 02:35 AM   #17
portabuddy's Avatar
Quote: Originally Posted by turbocad6 View Post
as long as you have patience & don't just give up & call it done, it'll get better & better each time you sand it & go a little more, looking good so far
be sure no silicone is on the surface of the face, it's impossible to get good paint adhesion on silicone, as long as it's all covered with bondo it's good
good luck with it
you can use acetone(home depot) or wax and grease remover(Auto body paint supply store) to get rid of the silicone its a good solvant...
Old 07-30-2007, 12:06 PM   #18
wow. looken good man. the acetone is just what I need right now. Thanks ^_^
incudie is offline   Reply With Quote
Old 09-25-2007, 05:51 PM   #19
Sorry I disappeared for awhile but for anyones thats curious or attempting to do this, here is what my screen ended up looking like.
Thanks again for everyones help.
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
FS: Custom made Honda Civic Dash panel w/ Xenarc 7" TS J187 Classified Archive 11 03-08-2007 01:10 AM
Custom Dash with 700TSV for 02+ Honda Civic Si xmadcowx Classified Archive 3 09-06-2005 11:12 PM
Mounting the Xenarc in the dash edrex LCD/Display 2 01-09-2005 12:55 AM
Mounting Xenarc inside dash - But removable! Pabs LCD/Display 11 09-06-2004 04:20 PM
