Notices
Old 07-19-2007, 11:39 PM   #1
Having to recalibrate every x minutes
I have just set up the carputer, and everything is working nicely except from the LCD - a JPP D700VT. After calibrating it is fairly accurate, but after some minutes - may be 5, 10 or an hour - it "forgets" the calibration and the mouse pointer is turning up no where near where i want. I cannot seem to find an obvious pattern either. It can happen while i am driving, while i am parked, when i am not touching the screen for a while, while i am stressing it etc.
Any ideas?
bjornix is offline   Reply With Quote
Old 07-20-2007, 02:07 AM   #2
Atleast you can calibrate... Everytime I use my lilliput and try to calibrate the software just crashes =[
Blacryan is offline   Reply With Quote
Old 07-20-2007, 08:54 AM   #3
tn6478's Avatar
lol new screen time. that sucks when the software you use crashes. You sure you install the right software.
tn6478 is offline   Reply With Quote
Old 07-20-2007, 09:42 AM   #4
BiGGy's Avatar
Have you pulled apart the monitor since new? i.e fabricated into a dash?
Mitsubishi Magna VR-X - Whitsundays, Australia
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
*768 X 1024 Narrow RR Skin
http://bigs.omfg.net.au/
BiGGy is offline   Reply With Quote
Old 07-20-2007, 01:05 PM   #5
No, i mounted the frame into the dash and the screen in the frame. I doubt the screen is damaged. I am wondering if this could be a ground issue as i know you can experience weird problems with this. If not it has to be on the driver/pc side and not the mounting.
Traffic Cams International v1.2.7 Enforcer Other Cool Stuff 643 11-05-2008 10:15 AM
FP doing something every 3 minutes? TheJack FrodoPlayer 3 02-04-2006 10:07 PM
Touchscreen starts off X-Y coordinates for first 10 minutes. judoGTI General Hardware Discussion 7 04-02-2005 10:24 PM
Xenarc Toushscreen "goes out" after a few minutes Namtaru LCD/Display 0 10-21-2004 05:05 PM
can the Opus stay powered up indefinately for STR? ie: no shut down after 20 minutes? pooshda Power Supplies 3 05-28-2003 10:45 AM
