Notices
Old 09-15-2002, 09:56 PM   #1
Xenarc Power
So has anyone come to a conclusion on powering the Xenarc in the car? Is it safe to use the vehicles 12v considering it's rated between 10-36v@1amp. Or is it better to use a pc's PS?
Brian Cozzens
Duke Nukem Forever / Max Payne
www.3drealms.com
Whaleboy is offline   Reply With Quote
Old 09-15-2002, 10:05 PM   #2
I've been using the car 12V adaptor for a month. Hasn't caused a problem yet. Now, if I could only force my xenarc to turn itself on when it is given power...
rdliou is offline   Reply With Quote
Old 09-16-2002, 06:55 AM   #3
ahhh, excellent. So did you splice the AC power supply and just run it to the cars 12v, or didja buy a generic 12v adapter+plug from radio shack or whatever?
Having the display come on when power is given to it would be wonderful, I keep hoping somebody is gonna come up with a simple circuit to throw a pulse at that sucker
Brian Cozzens
www.3drealms.com
Old 09-16-2002, 11:19 AM   #4
Registered User
Be warned:
Quote:
Originally posted by cng1
CRAP! Something has gone REALLY wrong!
The thing (reffering to his Xenarc monitor) was working on my home PC, through the wall outlet.
I take it outside and splice the power cord and run it inline with my power inverter's power/ground wires. PC in car comes on fine but no power to TV. Hmmmm, i take it back inside and wire the AC cord back to normal and it doesn't work INSIDE now!!! No power at all!!!!! Any ideas? I didn't think anything I did could've broken/fried it..... CRAP!
thanks,
Clayton
Rest of the thread here:
'03 BMW M3 6 spd.
Black/Imola Red
19's
Shuttle XPC w/ AMD 1800+
Opus 150w
Lilliput 7"
Wireless internet through my P900 and bluetooth
InFix is offline   Reply With Quote
Old 09-16-2002, 03:08 PM   #5
That's exactly why you run it off of the computer's power supply- It provides a true (or close enough) 12v source. A car can provide anything between 12-14vdc. Just because it hasn't happened yet doesn't mean it won't. Kind of a risky move with a $500 investment.
rammic is offline   Reply With Quote
Old 09-17-2002, 02:06 AM   #6
Registered User
The display is rated for a wide range of voltage. I don't have mine in front of me right now, but I think it went higher than 18V. Which would be fine for vehicle use.
I don't see any damage occuring from the voltage going to low, as the internal regulator would just brown out, so there is no worry about the vehicle power going below the recommended minimum.
It should be perfectly safe to run a FUSED line from your vehicles power, but be warned, DO NOT CROSS THE POSITIVE AND NEGATIVE LINES. You will fry it. As was deemed the case in that post referenced above by InFix.
[------------------|--] 90% Completed
Not installed, yet.
Developing Completely DirectX shell.
P4 1.7GHz, 256MB RAM, 40GB-7200RPM HD
Krazy Nemesis is offline   Reply With Quote
