Old 07-26-2007, 02:37 PM   #1
Can't get my lillut to power on
I have pictures showing my connections with voltage to the GL-701. I have 12 v on the battery wire. I have 4 v on the acc wire and these were both checked after the fuse with the ground from the lilliput.
AJWatU is offline   Reply With Quote
Old 07-26-2007, 02:41 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
4v from any car wire is a bad sign...
Old 07-26-2007, 02:43 PM   #3
I know it doesn't make sense it has 13v before i plug it in to the lilliput then when I plug it in it goes down to 4.5
Old 07-26-2007, 02:48 PM   #4
2k1Toaster's Avatar
well you over drawing your acc wire. What do you have hooked up to it?
As a test, use the wire coming straight from the battery to power both your screen's constant and switched input. This will make the monitor power up (or should) regardless of the state of the car. That way you can make sure the monitor works. If that works then you are going to need to move crap off your acc line to a relay tripped by the acc line.
Old 07-26-2007, 02:52 PM   #5
I will and then post back. thanks
Old 07-26-2007, 04:43 PM   #6
I wired it up to a different ignition wire and it works fine now. Thanks
Power supply Problem xGROMx Power Supplies 8 03-16-2007 01:19 PM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 01:18 AM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 12:08 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
Opus power supply issue dmazyn Power Supplies 2 10-15-2003 06:32 PM
