Notices
Old 07-29-2007, 01:07 PM   #1
Using Portable DVD Player For VGA display
I have portable dvd player I would like to use as a VGA or Composite display connection for my carputer. It only has audio and video outputs. Will I have to buy a special controller card OR can I solder VGA/Composite connections to circuit controller already in portable case? I would greatly appreciate website or old thread links. Searching for portable dvd player did not yield interesting results.
mpman is offline   Reply With Quote
Old 12-19-2007, 11:04 AM   #2
im tryin to do the same thing. My screen is showing all white and i have seven portable dvd players with 7" lcds i want to take the lcd out (raw lcd) and make it work with the video controller in my oprginal scrreen and input?
infamous350 is offline   Reply With Quote
Old 12-19-2007, 01:36 PM   #3
they're probably 1/2 res displays so may not be suitable for VGA connection.
pokki is offline   Reply With Quote
Old 12-19-2007, 03:29 PM   #4
Fusion Brain Creator
2k1Toaster's Avatar
They wont be VGA resolution in a portable DVD player unless it is a HD Portable Player, but I very highly doubt that.
So even if you get it working, it will be horribly fuzzy.
To get it working, you need a video controller board. It varies on the LCD screen itself. They range from $100 to $400 for the controller board. You cannot just solder on to the existing chip because all the video converting from digital dvd signal is done on a singal chip most likely. Sometimes they split analogue and digital, so it may be dvd --> optical decoder --> magic analogue chip --> digital decoded optical signal --> magic video driver and dvd decoder --> screen
You can only solder to the input of the video chip. So you would need to take your VGA signal out from the motherboard, then encode it into the proprietary digital signal using some custom hacked hardware, then solder feeds from that into the video decoder chip.
And as I said, even after all that you get a half assed blurry screen that you cannot read text.
Or for $200, you can get a 7" VGA touchscreen.
i have a portable dvd player that died (wont read dvd's but screen still works) kinggargantuan LCD/Display 10 06-15-2006 09:58 PM
Wtb: Portable Dvd Player, Mint Condition BIzFlawless Classified Archive 0 06-13-2006 12:24 AM
House dvd player in the car & Innotek ebay screen? hmm thesupe87 General MP3Car Discussion 8 09-07-2005 12:30 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 01:25 AM
