The MP3car.com Store
Thread Tools Display Modes
Old 07-29-2007, 04:17 PM   #1
My Photos: (0)
Lilliput touchscreen has to be replugged in everytime pc is turned on!
Hi all, i have jsut installed my touchscreen in my car and everythings owrks fine bar a few minor probs one of which is that everytime i turn on the computer in my car i have to unplug and then plug in the usb connector from the monitor into the pc/usb extension cable.
As soon as i plug it in again it works fine but once computer turns off and is turned back on the touchscreen does not work at all.
The odd times when i have turned it back on if i kept touching on the screen it would beep once and indicate a touch but not where i actually pressed and then that was it.
As soon as i re-seat the connector all is fine.
I have no idea why but i'd like the sorted asap as my connector is right under my centre console so i have to take it all apart again to get touchscreen working each itme i start the car!
grandimperial is offline   Reply With Quote
Sponsored Links
Old 07-29-2007, 06:41 PM   #2
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
is it connected via a hub or directly.
Enforcer is offline   Reply With Quote
Old 07-30-2007, 04:33 AM   #3
My Photos: (0)
It is connected to a 3m extension lead which is connected directly to the motherboard
Old 07-30-2007, 07:22 AM   #4
Confusion Master
Enforcer's Avatar
My Photos: (1)
Shouldn't be a problem, that's how mine is connected and I have no such issues.
Old 07-30-2007, 08:19 AM   #5
GiODi's CarPC Specs
Vehicle: 2001 Infiniti QX4
My Photos: (1)
Is the touchscreen not recognized by windows or does it just not work?
GiODi is offline   Reply With Quote
Old 07-30-2007, 10:07 AM   #6
My Photos: (0)
After much searching i believe the prob is the same as what a lot of people were having, which is that when windows awakes fom hibernation the USB devices do not.
I read about devcon etc but im not keep on the idea of adding something to my start up for fear of it slowing up the start up process.
Also i have no knowledge of coding and so therefore im not sure i would be able to use it.
Is there no alternative solution anyone has found to this prob?
IE a patch for windows or for the motherboard drivers.
As in my house my pc running XP SP2 (same as car) has no probs resuming from hibernation with USB device functionality.
Sponsored Links
Trackbacks are Off
Lilliput works on home pc but not car PC!!!!!!!!!! lax4321 LCD/Display 13 02-24-2007 05:24 PM
Lilliput 8" touchscreen problems with touchscreen kit Iggyg00 LCD/Display 1 01-31-2005 11:35 AM
Want to make $150? (trade your touchscreen lilliput for an RCA lillipt) minghi Classified Archive 0 01-24-2005 11:55 PM
*****ing lilliput touchscreen mrzigzag LCD/Display 21 04-13-2004 02:31 PM
WTB Lilliput with broken touchscreen or Lilliput without touchscreen dettman23 Classified Archive 1 04-11-2004 08:12 AM
Sponsored Links
Ad Management by RedTyger
