Old 08-08-2007, 12:06 AM   #1
Wagonmaster's Avatar
touch screen cal off, any suggestions?
I finally got my TM-868 to cal without locking my PC up but, when I touch the screen it is off by about 1/2" from where I touched it.
I'm using touchkit and have tried 4, 9 and 25 point cals.
Russ
'93 Caprice Classic "Woody"
Wagonmaster is offline   Reply With Quote
Old 08-08-2007, 04:00 AM   #2
Which version of touchkit do you have? Download the latest ones from here:
http://www.cartft.com/support/drivers/TFT/
www.computer-forums.net
kostyanj is offline   Reply With Quote
Old 08-08-2007, 06:07 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
Or here: http://www.eeti.com.tw/web20/eg/drivers.htm
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 08-08-2007, 12:17 PM   #4
tn6478's Avatar
make sure your windows look right on the screen. meaning everything fit. if its not it will be off. Also make sure if you did fabricated the screen that its not bending it. That will make it go off too
tn6478 is offline   Reply With Quote
Old 08-08-2007, 01:22 PM   #5
As a matter of fact, I am also having a problem with the window size, there is a "no man's land" at the bottom of the screen that the pointer dissappears into. I feel like it's a driver problem but I'm using the latest one.
HMMMM
Russ
Old 08-08-2007, 01:24 PM   #6
Did you install the touchkit drivers from the link I posted?
Old 08-08-2007, 09:52 PM   #7
I'm already running touchkit 4.3.8.4207
I think the problem may be with the driver for my chipset. I'm running a Via EPIA M10000 micro-ITX
Russ
Old 08-10-2007, 12:21 AM   #8
slvrsol's Avatar
Mine isn't very accurate either.. I calibrated by trying to offset the inaccuracy and using edge compensation. Also.. just in case you aren't, use a stylus.
slvrsol is offline   Reply With Quote
Review: TView 8" LCD Widescreen Touch Screen 56k Beware AcuraTLFan The Review Palace 26 01-30-2008 02:01 PM
CoPilot best input suggestions w/ touch screen Grruel GPS 4 09-03-2006 02:41 PM
Lilliput 8" touch screen backwards - FC4 DJBigShow Linux 9 08-04-2006 02:43 PM
Lilliput touch screen Help..please avn128 LCD/Display 2 08-03-2006 04:20 PM
Need touch screen advice sciff5 LCD/Display 0 05-29-2005 09:58 PM
