Old 08-09-2007, 02:41 PM   #1
Nexson's Avatar
Question Need Replacement 8in LCD Glass, universal?
Hey guys, the touchscreen broke on a 8in SHARK VGA screen that i was installing, I am wondering where i can get a replacement and if the connector from the glass to the circuit board have the same universal connector, meaning that I wouldn't have to buy a shark touchscreen replacement since i can't seem to find it.
Maybe xenarc or lilliput 8'' glass would work?
thanks.
Nexson is offline   Reply With Quote
Advertisement Sponsored links
Old 08-09-2007, 03:07 PM   #2
MySQL Error
Sonicxtacy02's Avatar
are you sure it was the "glass" and not the touchscreen?
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Developer of: RRFusion, MovieTimes, (new)RRMail
Coming Soon:RRChrome, RR Plugin Browser & CentraFusion
Old 08-09-2007, 03:15 PM   #3
Nexson's Avatar
it was the touchscreen, sorry I refered to it as glass, i am still newbie
Old 08-09-2007, 03:41 PM   #4
MySQL Error
check the physical dimensions of it and compare the the 8 inch touchscreens on digitalww.com. If they match you can use that touchscreen IF you buy the controller too
03 Acura RSX Coupe
Old 08-09-2007, 04:57 PM   #5
Nexson's Avatar
they dont even sell a 8 inch on there that I saw.
Old 08-09-2007, 09:44 PM   #6
Nexson's Avatar
anyone else, i need a 8in replacement touch panel
Old 08-09-2007, 09:56 PM   #7
fixerofallthing's Avatar
I have bought one from them, they do sell tem. If it is not listed then email or call.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is online now   Reply With Quote
Old 08-10-2007, 08:05 AM   #8
MySQL Error
they definitely sell them there in the input devices category
03 Acura RSX Coupe
Old 08-10-2007, 01:58 PM   #9
Nexson's Avatar
yes I saw the 8 in i need for $100 but it says out of stock, I emailed them, but I do not see a number anywhere
Old 08-10-2007, 02:32 PM   #10
MySQL Error
he will get back to you but fwiw the touchscreen is 50 and the controller is 50. Its not 100 for just the touchscreen.
03 Acura RSX Coupe
Old 08-10-2007, 04:14 PM   #11
Nexson's Avatar
ok, sorry but I was just a little bit confused, the controller would be what?, by the looks of it, the connector on the touchscreen would fit right exsisting port of my 8in screen
Old 08-10-2007, 10:56 PM   #12
Nexson's Avatar
Old 08-11-2007, 08:07 AM   #13
MySQL Error
it could.. it could not.. really depends on what screen you have. I know nothing about our particular model. If you take a pic of the small rectangle in the back of your touchscreen that as a bolt attached i can tell u if it will work.
03 Acura RSX Coupe
Old 08-11-2007, 10:14 AM   #14
Nexson's Avatar
ok man, really appreciate your help, here's the pictures I just took.
Old 08-11-2007, 11:28 PM   #15
Nexson's Avatar
anyone have that type of touchpanel, that i can replace it
Lost cylinder fuse in my LCD monitor. What amp replacement? PapaPrem LCD/Display 3 08-13-2006 01:13 PM
LCD off ebay, replacement connector cable? Xander LCD/Display 2 09-27-2005 08:54 PM
how to fix broken LCD rear view mirror glass yoyoshopping Newbie 12 09-17-2005 01:09 PM
DB44 - Universal LCD connector Fosgate General Hardware Discussion 3 01-06-2001 06:19 AM
