Old 09-21-2002, 05:56 PM   #1
Registered User
felix99's Avatar
Grafical LCD => Soft for T6963c???
Hi,
After playing around with HD 44XXXX Displays me and a friend of mine now wanna go into grafical LCDs . We have choosen the T6963c controller because those lcds are cheap on ebay
Does someone know some good links with good windows software ( if possible freeware ) or free sourcecode ?
Many Thanks
Felix
=>> Carpc Version2 -- Epia M 10K based<<=
::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
::trying to build second low cost carpc::
::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
felix99 is offline   Reply With Quote
Old 09-21-2002, 06:28 PM   #2
Raw Wave
Rob Withey's Avatar
I wrote a driver for the 6963 a while ago. May be some use, it's on my website in the downloads section.
Rob
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 09-22-2002, 01:22 AM   #3
I just found this library of C code for the 6963C chip:
http://www.ramtex.dk/glcd/glcd.htm
it says its for running it on embedded processors, but i dont see why it couldnt be made to work from windows.
Charliey is offline   Reply With Quote
Old 09-22-2002, 07:44 AM   #4
Registered User
felix99's Avatar
Thaks for the links .
I found some soft but only for those "big" 240x128 displays.
I m searching for soft for 128x128 or such.
( am still searching for Linux because because ther's not very much soft for windows)
The fiúnctions that interest me are mainly , Winamp, clock , display pictures and text-
Felix
Old 10-07-2002, 10:57 AM   #5
I have some software for T6963C and KS0108 controllers available at my site: http://www.skippari.net/lcd/
Also source code for my own programs is included. Only 128x64 resolution is currently supported for the KS0108 controller and 240x64, 240x128, 256x40 and 128x128 for the T6963C.
I've been planning of doing a car computer / mp3 player using a 240x128 T6963C display for the interface but haven't had time for that yet.
If you have any questions concerning the T6963C controller let me know and I might be able to help.
Henri is offline   Reply With Quote
Old 10-08-2002, 11:35 AM   #6
peter3's Avatar
check this site it's in dutch but who knows?
http://gfxlcd.schijf.org/
or check this :
http://gathering.tweakers.net/
and use the search
good luck
peter3 is offline   Reply With Quote
Old 10-09-2002, 08:35 AM   #7
http://www.mini-itx.com/projects/spa...spacepanel0006
check that out for links to software
mp4runner.com
saletel is offline   Reply With Quote
Old 10-09-2007, 03:19 PM   #8
Cool
>it says its for running it on embedded processors, but i dont see why it couldnt be >made to work from windows.
I've been using it for multiple projects, including linux. It has a display simulator,
that works with both the borland and msvc C/C++ compilers for windows. I have
used it for other windows apps also, it works fine.
mondeodriver is offline   Reply With Quote
