This is an awesome thread. Great photo and video work!
I was reviewing the 3M Anti-Reflective AR-Mx200 literature and I think the AR-M200 and AR-MP200 are superior to the AR-MR200. I conclude this since the AR-MR200 brochure states expected lifetime of only 3-6 months. Now if AR-MP200 uses
permanent adhesive I'm hoping it is
different from the AR-MR200. Maybe the fingerprint layer wears out first from heavy stylus usage?
AR Product Family
AR-MR200
AR-M200 & AR-MP200
AR-M200 Film and AR-MP200 Properties
• Specular Reflectance <1.1%
• Transmission 93%
• Haze <= 7.0%
• Gloss at 60° 90-115 gloss units
• Adhesion Cross hatch with Scotch® #610 tape - No delamination
• Hardness => 3H pencil hardness on hardcoat side
• Abrasion 10 rubs #0000 steel wool at 160 g/cm2 - Light scratching
• Chemical resistance Window cleaner, IPA, motor oil, coffee, permanent marker
or water - No effect
• Flexibility 2cm mandrel - No crack in tension or compression
• Surface energy <30 dynes/cm
• Substrate thickness .005″ polyester (PET)
• Format 13″ x 22″ (330mm x 559mm)
• PSA peel force to glass >1000 g/in
ARMR-200 Properties
• Specular Reflectance <= 1.1%
• Transmission > 92%
• Gloss 75-110 gloss units
• Thickness Base 5 mil, Adhesive 1 mil
• Pencil Hardness >= 3H
• Durability 10 rubs at 160g/in2
• Solvent Resistance Window cleaner, IPA, 10W-40 oil, Coke®, coffee, Sharpie®, water
• Environmental Heat/Humidity 65°C/95% RH for 500 hrs
• Dry Heat 85°C for 500 hrs
• Thermal Shock Resistance (Hot/Cold) -35°C to 85°C, 1hr cycles for 8 days
I requested samples awhile back when I was planning to upgrade my Shark SHK804 8.4", but after cracking the case I saw the TORiSAN LCD and I didn't have a good feeling. I received a follow up e-mail from Linda at 3M asking what I was doing and what did I really need. I caught the DIY LCD kit bug and dropped this film upgrade endeavor.
I am now rolling my own transflective LCD display and it looks like I could use a 3M AR film to protect the surface of the panel, since I will be using IR touchscreen with no glass. I may also need UV protection but that is another story. I think I'll request the AR-M200 or AR-MP200. Did anyone request these versus the AM-R200, which appears to be too small? If so, was the sheet large enough to fit an 8.4" screen? I wonder if I need optical bonding equipment for the AR-MP200?
I will run this by Duayn.
