Notices
Old 08-21-2007, 10:27 PM   #1
Powering my Xenarc
hey,
got my Xenarc all installed in my dash. the Xenarc specs say that it takes 11V-24V ...so im guessing unregulated..
was wondering if i should power my xenarc up from the battery..since it only pulls 1amp i can tap into the power wire and ground to the ground wire...
or should i tap into one of the molex connectors power and ground wire...that would be regulated power..but more of a headache i suppose in terms of neat wiring...
anyway any suggestions will be appreciated
or i guess..what i am asking is..will it be okay if i tap into the unregulated power wire or would it be better to tap into molex...
P.S.: no i dont have a distro block...
MastaShake is offline   Reply With Quote
Old 08-21-2007, 10:36 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
xenarc uses unregulated power just fine. That is a feature of it
Old 08-21-2007, 10:37 PM   #3
sweet, so i can tap into my power wire..it will save me the headache of running an extra long wire to the trunk...
thanks for the quick response..much appreciated.
Old 08-22-2007, 12:48 AM   #4
MAZINGA3's Avatar
Could anyone explain about "tap into power wire" how to??
Cavalier Unknown > Caravan '00 > Sentra '00 > EscaladeESV Platinum '04 > Odyssey '06 [accident] > Mazda3 '06 + ESV
MAZINGA3 is offline   Reply With Quote
Old 08-22-2007, 12:55 AM   #5
2k1Toaster's Avatar
Well for just a screen, take the + and solder it to the + wire for your radio harness if you must. I always suggest a seperate wire from the battery. Then the - wire from the screen goes to a good paint-free stable point.
Old 08-22-2007, 02:14 AM   #6
crooper's Avatar
So if the screen is wired to unregulated the power, does it only turn on with a VGA signal?
crooper is offline   Reply With Quote
Old 08-22-2007, 09:14 AM   #7
no, you have to run an ACC wire to it...i think that turns it on.
Old 08-22-2007, 09:06 PM   #8
cdcamaro9534's Avatar
Run a separate wire to power the display. I tapped mine into the old radio harness, and it just didn't have the capability of providing what the display wanted. Guessing it was just to bad of a voltage drop on the line. Everytime I'd turn my windshield wipers on, or my headlights, the display would kick of. And I would have to shut it off and back on. After running a separate wire, all was cured. Unless your car has better wiring.
1995 Chevy Camaro
VIA EPIA M10000 Mini-ITX Motherboard
WD80 Hard Drive
WinTV Tuner
Iguidance GPS
Road Runner Frontend w/ Liquid Smoke's skin
Xenarc 700IDT with DVD CDR/RW
MySpace Link
cdcamaro9534 is offline   Reply With Quote
Old 08-22-2007, 11:41 PM   #9
i used the wire harness to get the power for my LCD and it didnt even look like it turned on..something weird.
Old 08-23-2007, 07:39 AM   #10
Neither darque nor pervert
DarquePervert's Avatar
Did you have a signal going to it?
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 08-23-2007, 10:19 AM   #11
i did not have a VGA signal going to it.
i am having bigger problems over here
http://www.mp3car.com/vbulletin/powe...then-dies.html
Xenarc causing noise (powering issue) davem LCD/Display 4 05-20-2006 04:01 PM
Powering new Xenarc 7" -Dead Avatar Monitor alexvr1 LCD/Display 0 04-18-2006 04:53 AM
Powering Xenarc Cheekz185 LCD/Display 8 05-26-2005 09:14 PM
Question: Powering Xenarc from Morex 80w? eleventh Power Supplies 9 12-05-2004 09:58 AM
Strange problem powering xenarc from 90w Opus :( Brettster LCD/Display 3 05-11-2004 06:19 AM
