The MP3car.com Store
Thread Tools Display Modes
Old 08-23-2007, 05:31 PM   #1
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
Home LCD monitor in car?
I want to get an LCD monitor to stick in my rear seat for my kids to watch movies on. I was thinking about getting a 15" regular computer lcd monitor. Can I just plug this into my CarPC for power somehow? Or do I need to get an inverter? What's the usual voltage requirements?
crooper is offline   Reply With Quote
Sponsored Links
Old 08-23-2007, 05:34 PM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
usually they require weird voltages not easily had in a car environment. An inverter would be your best bet if you are too finicky about noise issues and waste.
I checked a few a while ago, and they were 19v (Old Dell one), and 16v (Viewsonic I believe). Both voltages are attainable, but not in the multi-amperage range needed. Easily that is.
Old 08-23-2007, 05:45 PM   #3
crooper's Avatar
My Photos: (0)
I did a search on 15" lcds and they were in the range of 20-30 watts, so that would be like 2amps or so at those weird voltages, right? so would that mean that i need a pretty tiny inverter.
Old 08-23-2007, 05:48 PM   #4
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
I used a 15" LCD in my truck for a while because it was all I had and i was in the preliminary build phase.
I was powering it with an inverter, but it could take 12v, if I wanted to hack together a connector. I never bothered, since it was just a temporary setup anyway.
Check the power requirements of various monitors. You might find one that will meet your needs.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 08-23-2007, 05:53 PM   #5
crooper's Avatar
My Photos: (0)
Do they need a pretty clean signal, or will a cheap inverter do? I have a 75 watt cigarette lighter inverter that i'm thinking about hacking apart to stuff it somewhere less visible.
Old 08-23-2007, 05:59 PM   #6
My Photos: (26)
I used a cheap $30 400w inverter that I got at Fry's. They sell the same inverter at Wal Mart.
It worked like a charm.
My Worklog
Old 08-23-2007, 06:56 PM   #7
crooper's Avatar
My Photos: (0)
Awesome, thanks! I sure am glad you guys are on here all the time.
Old 08-27-2007, 05:36 PM   #8
crooper's Avatar
My Photos: (0)
As a follow-up, I got a 200 watt Black & Decker inverter at Walmart to run my 15" Viewsonic LCD and it worked great. The kids were pleased.
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Why not Home PC speakers for the car? RedGTiVR6 The FAQ Emporium 22 03-05-2008 03:35 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
