The MP3car.com Store
Thread Tools Display Modes
Old 08-25-2007, 12:22 PM   #1
My Photos: (0)
Lilliput 629GL-70NP - No Input Signal
I have just gotten to install this device after too many months working on my system.
For testing, I'm using the 110v adapter than came with the device.
I have the cable from the device plugged into the VGA port on a laptop.
I have the USB cable plugged into a USB port and the latest(?) TouchKit drivers installed for XP.
When I give the device power, the Red power light comes on as do the blue lights. They then go off.
I also see PC on the upper right of the display for a short while.
I then get a red bordered box with the message "No Input Signal" that shortly disappears leaving a black screen.
Only the power and tv/av buttons on the remote and the device get a response. Menu gets nothing.
Win/XP doesn't know about the device i.e., it is not in the display settings.
I'm beginning to belive it is a bad cable. If so how can I test it? Any specs on the pins?
If the cable is bad, where do I get one?
Regards,
Jim
obrienj is offline   Reply With Quote
Sponsored Links
Old 08-26-2007, 05:49 AM   #2
My Photos: (0)
Never mind. The warranty on my brain ran out when I turned 65.
All works just as it is supposed to.
Regards,
Jim
Old 09-01-2007, 11:59 AM   #3
My Photos: (0)
How did you fix it again...
I really got to get this thing working. What exactly did you do ? I have the same symptoms
Antman56 is offline   Reply With Quote
Old 09-01-2007, 03:33 PM   #4
My Photos: (0)
Antman56,
On my laptop I have a function key that switches from the laptop display to an attached display.
When I pressed it the laptop display also showed on the 629. When I pressed it again the image only showed on the 629.
I then went into the Control Panel->display and set the resoluton for that display to 800x600.
At least I think that is what I did. As I said the waranty on my brain ran out when I turned 65.
It was actually a sequence I should have remembered as it was exactly the way I got a 21" auxillary display to work on another laptop.
Regards,
Jim
Old 05-04-2008, 03:09 AM   #5
My Photos: (4)
anyone found a solution for this matter yet?? thanks!
vaige is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
No Signal on Lilliput 7 Inch touchscreen. SuperDave01 LCD/Display 7 05-04-2008 09:36 AM
FS: Lilliput 7" Touch Screen XGA TFT Car Monitor 629GL jwong3854 Classified Archive 8 11-15-2006 03:07 PM
Need a lcd with s-video or rca video input!!! Need to send signal from my laptop!!! bankingdom LCD/Display 3 01-28-2005 03:32 PM
Lilliput composite input flashing? Misanthro LCD/Display 1 12-09-2003 03:58 PM
Input signal for 6" Sharp LCD screens Fosgate General Hardware Discussion 5 05-03-2000 11:23 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
