If youre only turning on/off back light, it should be alright.
The problem occurs is when you accidently short the power supply wires when your computer is running. Then it restarts.
The other problem that can happen is its not good for the LCD processor when there is a signal applied to the data pins (ie it is plugged into the parallel port), but it does not have power supplied to the power supply pins.
So, only install a switch to turn off the back light, not the main power to the screen, unless you remove the parallel connection with it.
