The MP3car.com Store
Thread Tools Display Modes
Old 08-26-2007, 02:17 AM   #1
My Photos: (0)
Dual monitor on car pc
Hey, I'm trying to do a dual monitor setup on two monitors. Basically i want my touchscreen monitor to control everything and i want the other monitor to be for viewing as the touchscreen on it got messed up and doesn't function for some reason anymore. I just dont know how i would go about keeping all the controls on one monitor. Prob hard to understand but if anyone understands what im sayin and can help in any way i would appreciate it, thanks. Seth
blueaccord19 is offline   Reply With Quote
Sponsored Links
Old 08-26-2007, 10:18 AM   #2
bbalazs's CarPC Specs
Vehicle: 2001 Renault LagunaII 2.0 IDE
My Photos: (15)
I did the same thing on my EPIA V10000. I have applied a secondary video card into the PCI slot. I set the original onboard video card as primary and the additional card as secondary. All the controls have on the first display, but if you want you can simply extend the prog output.
I viewed the primary (an LCD TV) and my daughter was amused with the full screen cartoons in the back seat at the same time.
bbalazs is offline   Reply With Quote
Old 08-26-2007, 03:17 PM   #3
My Photos: (0)
ok thanks, yeh i haven't tried it yet but i was just thinkin in my head it may not be so simple but i'll have to try it. Only prob is the pc i have doesn't have pci slots, everything is onboard. I have seen single to dual vga cables and usb devices used to add an additional monitor but i'm not sure if they will work or if they are anything of quality but i'll wait and try it and see maybe it'll work how i want it to.
Old 08-28-2007, 02:47 PM   #4
dprothero's CarPC Specs
dprothero's Avatar
Vehicle: 2000 Honda Civic
My Photos: (31)
A VGA adapter "Y" cable will work, but you'll get the SAME image on both monitors. If that's what you're going for, then it's a pretty simple setup.
However, if you want different images on the two different monitors (which is the setup bbalazs was describing), you'll definitely need a second video card. For your situation, you could use a USB video adapter like the following:
http://www.usbgear.com/USB-Video-Card.html
Mind you, I just did a quick Google search for "USB video cards", so you'll probably want to shop around more.
Good luck.
FYI... I'm doing a hybrid of both... two video cards, LCD touch screen up front for primary control, two video screens in the back (both connected with a "Y" to the secondary video card) so the two back screens show the same image. Not sure what front-ends are going to support that yet, or if I'll have to roll something on my own.
David
dprothero is offline   Reply With Quote
Old 08-29-2007, 11:03 PM   #5
Bizzar's CarPC Specs
Vehicle: 95 CX Turbo Civic Hatch
My Photos: (0)
David
That only works if you have 2 identical monitors. Trust me I tried :P
My carpc post: Relocated a/c + 6000 watts and 300hp *tons of pics*
http://www.mp3car.com/vbulletin/show...highlight=6000
http://img214.imageshack.us/img214/2...burnoutzf6.jpg
Bizzar is offline   Reply With Quote
Old 08-30-2007, 11:27 AM   #6
dprothero's Avatar
My Photos: (31)
Thanks Bizzar. Actual field experience is always better than theorizing.
2000 Honda Civic Sedan
2004 Honda Odyssey: worklog
Old 08-30-2007, 01:26 PM   #7
dLockers's CarPC Specs
dLockers's Avatar
My Photos: (0)
Power the other monitor etc, plug another VGA cable into your carpc (or put another graphics card in), go on the bios of your pc and set the primary/secondary graphics (primary being your working one), then you should download 'ultramon' (or pay, iirc), and it will be like on windows, you wont however be able to do much with the second monitor unless you hook up a mouse.
Once it's hooked up just configure ultramon (pretty simple), then hopefully when you drag your finger selected on a programmes top bar it will shoot to the other monitor.
Otherwise you will definatly need a mouse.
dLockers is offline   Reply With Quote
Old 08-30-2007, 02:25 PM   #8
dprothero's Avatar
My Photos: (31)
dLockers... dude.... thanks a ton. Didn't know about Ultramon. Just checked out their web site and this software is exactly what I need. It's even programmable via VBScript, so should be easy enough to integrate with any front end (i.e. to play videos, have it launch video player, full screen on other monitor).
Edit: It's $39.95, but not bad if you need this.
Last edited by dprothero; 08-30-2007 at 02:27 PM. Reason: Adding additional info (price).
Sponsored Links
Trackbacks are Off
In a real PC car struggle markland556 Off Topic 10 06-27-2007 11:36 AM
New to Car PC, here is my setup. BarinaHum Newbie 6 11-06-2006 08:16 PM
First install of car pc working :) optip General Hardware Discussion 2 09-09-2006 07:13 PM
PC wont boot while car runs Empreez Power Supplies 0 11-30-2005 04:25 AM
Sponsored Links
Ad Management by RedTyger
