Old 08-28-2007, 06:00 PM   #1
1druid1 is an unknown quantity at this point
LCD Specs
Hi All
I have a 7" Sharp QPWBS1017CPZZ LCD panel that I have lost the power / composite connection adaptor for..
This is a two part question..
1) I have searched the web but cant find much information on this panel, anyone have or knowthis panel that can give me the pin outs and the supply voltage / Current so that I can create by own composite and power adaptor?
2) Is it possible to convert this panel to run of VGA
Any and all help is appreciated.
Cheers
Dougie
1druid1 is offline   Reply With Quote
Old 08-28-2007, 10:24 PM   #2
marshallh's Avatar
marshallh is on a distinguished road
If you post pictures it will be easier to find where the signals should be going to.
Do you still have the controller board or just the bare LCD itself? You'll need a controller to do anything with it.
Also, it is possible to run a computer VGA signal to a composite screen. It will look absolutely terrible, and I advise against using it unless you're only using it for VHS movies.
Progress:
[■■■■■■■■] 100%
Mitsubishi 3000GT car computer
Previous budget Honda carputer
marshallh is offline   Reply With Quote
Old 08-29-2007, 05:13 PM   #3
Hi All
Here are the pics of the LCD, ave got a crap camera so they aint great, hope they help though..
Cheers
Dougie
Old 09-04-2007, 09:49 AM   #4
Hi all
Anybody have any joy with identifying the details of the pinouts?
Cheers
Dougie
Old 09-04-2007, 10:37 AM   #5
bbalazs is an unknown quantity at this point
Not a joy, but sometimes neccessary...
To identify the power connector is quite easy. You need a cheap multimeter ('connection' beeper is an advantage, othervise measure resistance, under 1 Ohm is connected)
Most important is the ground. The large metal (often covered with isolator resin) parts on the PCB. The housing of the LCD itself is ground.
At least one pin must be ground and I strongly believe the shielding of the connector also connected to ground.
Next is the power (I suppose 12V, but is can be different). The location, where the cord is connected to the PCB, there are printed wires on the PCB. The thickest wire (which is not the ground). Try to find a stabiliser IC (7805 or so) and the input is power. Often protected by a fuse (marked as F1, F2 or so on the PCB).
When the power and ground are present, the monitor must show a sign of life (at least a LED is lighting in red or green), and after pressing the power the backlight usually switched on (at least for a bliss).
Other wires are signals, so there is not a huge danger to misconnect them.
Guess. Keep the ground-ground connection between signal source and your monitor!
Those signals often have check points on the PCB (small silver METAL dots - not covered with green resin) and there are 'speaking' titles in white (AV_in or so).
bbalazs is offline   Reply With Quote
need a ribbon extension cable for LCD, I have all the specs mattress LCD/Display 3 05-05-2005 11:41 PM
