Notices
Old 08-31-2007, 01:11 PM   #1
Xenarc Driver Issue
I searched, but couldn't find this one:
My 700IDT was working great for many weeks, but now the touchscreen shows up as 'unknown device' under the USB heading in the device manager.
When I try to point to the TouchUSB.inf file (tried both of the latest versions) it says that the location doesn't contain drivers for the device.
I verified that the touchscreen is the unknown device by plugging in/unplugging.
It previously worked on my 1.1 and 2.0 ports, but now works on niether, but always shows up as 'unknown device' and won't accept manual driver updates.
All other USB devices still work perfectly.
Any ideas?
brad1011a is offline   Reply With Quote
Old 08-31-2007, 05:52 PM   #2
Solved it with the 4.0.2.1929 driver, which allowed manual adding (no device/driver mismatch error). Hmmm...
Old 10-08-2007, 10:58 PM   #3
same problems
i just made the drive from cali to texas and about halfway i turned my car off to get gas, and turning it back on the touch screen doesn't work.
looks like i'm having the same issue as you, now i can't install the touch screen because it just appears as an unknown USB connection and won't let me manually install any of the drivers that xenarc has listed because they 'don't contain any information about my device'.
any other advice you can give? i tried the 1929 drivers to no luck...
r
Cerztrueheart is offline   Reply With Quote
Old 10-09-2007, 11:05 AM   #4
Sorry I can't think of anything. Did you try uninstalling the original touchkit first? My next step was going to be re-installing Windows. Maybe if you tried that and only stick to the 1929 drivers after? I haven't had any problems after using that driver...
Need Driver for xenarc! spony311 Newbie 3 05-23-2007 03:21 PM
xenarc 700tsv g35 install issue ultrA_Cowboy LCD/Display 4 09-12-2006 12:56 PM
Pandora w/ Xenarc 700TSV and Barrel Connector froalskiner General Hardware Discussion 7 07-20-2006 03:39 AM
7TSV Xenarc Touch Issue IntellaWorks LCD/Display 0 11-01-2005 10:36 AM
