Old 09-04-2007, 05:43 AM   #1
NiGoea is an unknown quantity at this point
HELP - Don't able to set 800x480 :(
Hi guys !
Now at long last I have my Lilliput EBY701. But I'm not able to set in WinXP the 800x480 resolution. I checked all the settings, there is 800x600, 848x480, 960x600 but not the lilliput's native resolution.
I tried Powerstrip, but nothing happened.
WHAT CAN I DO ?
In the other resolutions the output is very bad.
Please help me
THANKS,
bye
NiGoea is offline   Reply With Quote
Old 09-04-2007, 05:57 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
It would help o know what video you're using.
Onboard video on a via EPIA-series motherboard? You're pretty much SOL.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-04-2007, 06:40 AM   #3
Well, firstly I tried my GeForce 6800 on my desktop pc. It doesn't have 800x480.
But now I tried also the carpc's video card: an integrated Intel 82815, with 32Mb. And also there, there is not lilliput native resolution.
Please help me, otherwise I spent a lot of money for nothing
Old 09-04-2007, 04:58 PM   #4
nst6563 is an unknown quantity at this point
I also have the 701 and it displays 800x600 perfectly fine. using i845g embedded graphics. can't set 800x600. I haven't tried Powerstrip, but I think you can run custom resolutions with it.
nst6563 is offline   Reply With Quote
Old 09-04-2007, 05:07 PM   #5
I don't understand you at all. Now you use 800x600 or 800x480 ? If you also tried 800x480, can you conferm me that 800x600 is not, compared to 800x480, too bad ?
Powerstrip allow you to select the same resolutions windows allow to choose. Nothing more than them.
Old 09-04-2007, 09:11 PM   #6
I use 800x600. It looks good.
Within powerstrip, you should be able to create a custom monitor driver, and specify resolutions within that driver. You should also be able to create a custom resolution and have Powerstrip switch to it on bootup. This was/is used quite a bit with HTPC setups which have video cards which don't display the desired resolution, or there is unwanted clipping in the standard TV resolutions.
:edit: try this link for a go at powerstrip - http://www.xenarc.com/faq.html#QA1
here's a thread on the subject of 800x480 http://www.mp3car.com/vbulletin/lcd-...m-drivers.html
Old 09-06-2007, 07:19 AM   #7
Thanks a lot guy ! I resolved the problem using powerstrip just two days ago
Unfortunately powerstrip can't force a specific resolution in every video driver, so I've installed an external video card, increasing the requred spice
Can a Lilliput display a native (800x480) resolution? Shamingo Newbie 6 06-23-2007 11:45 PM
I cannot get the RR to run at 800x480 dasoviet Road Runner 4 03-05-2007 07:10 AM
Has anyone EVER gotten a Lilliput to detect 800x480? larry_llama LCD/Display 49 12-03-2006 03:05 AM
2 sub set up GeeZeR Car Audio 2 07-30-2005 01:26 AM
800x480 60HZ vs 800x480 61HZ? theheel LCD/Display 1 04-25-2005 10:42 PM
