Please inform us about the warranty (I suppose it is out) and something about your abilities (I mean whether are you a handy man or not, have you any knowledge about electronics, have a multimeter or not) what are you prepared for and whether are you brave enough to open it for reparation.
I think the root of the problem can be two things:
1. It is not able to recognise the video signal any more. It can be a problem of a simple capacitor, but more often the main IC is faulty...
or
2. The backlight unit consumes too much amperes therefore the unit protects itself (the cause can be a short-circuit or overheating).
The most frequent cause of this is a fault of one FET or transistor near to the transformer. In this case the brightness is reduced.
When the backlight unit gives maximal (normal) light during the 3 secs, the problem can be around the tuning voltage that determinates the brightness by the controller IC. At the ignition the CCFL tube is driven by a near-maximal 50-50% PWM, but after it must be reduced, because the whole backlight system is designed for normal operation. There is a high voltage feedback loop that senses if the ignition is complete. This unit could be faulty, so the PWM remains maximal, therefore it consumes too much power and the protector circuit inhibits the unit.
It is important to know, that backlight and LCD are working SEPARATELY, so you can replace the backlight unit with an independent one (eg. from a PSONE or so).
When the backlight is off, the LCD keeps working, but you have to apply a strong illumination by a reading lamp and a video source with high contrast (eg thick black and white stripes or chess fields) for recognition. You must see the image on the dark LCD...
It is not neccessarily true in your case (eg. the whole monitor could be switched off), but it does worth a try...
