Notices
Old 09-06-2007, 03:49 AM   #1
Bimmerstyle's Avatar
Want my "beep" back...
Hi guy's, I've searched the forums and almost everybody wants to get rid of the beep when the touchscreen is pressed.
Now, I don't. I like my beep. My beep gives me confirmation if the touchscreen is pressed or not and I find it very convenient.
Only problem is: My beep is gone! I've recently added an external USB Soundblaster Extigy to my setup and now my beep is gone. It's not gone entirely but it sits in my PC instead of my speakers now and since my PC sits in the trunk for me my beep is not there anymore .
So seriously, I'm using a lilliput screen and the touchkit software. It seems as if the software thinks there is no soundcard/speakers attached anymore to the PC and it simply play's the beep through the PC speaker. Do any of you know a way to get it back on my speakers through the external Extigy soundcard?
Help me find a way to get my beep back! I really want it back! Thnx!
BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
Bezel Worklog -My Install -My Website (Dutch)
Bimmerstyle is offline   Reply With Quote
Old 09-06-2007, 06:58 AM   #2
Confusion Master
Enforcer's Avatar
Beep Beep
Enforcer is offline   Reply With Quote
Old 09-06-2007, 08:14 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
You can turn on the beep in the touchkit coontrol panel, I believe.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-06-2007, 12:34 PM   #4
Maybe I was a little too melodramatic in the first post an not clear enough? Could it be?
I know the beep can be turned on in the touchkit software. It is turned on for over a year now.
Everything worked fine for me as long as I used my on board via soundchip. The beep was played trough the car speakers.
But a couple of weeks ago I replaced the on board sound with an external USB soundblaster Extigy. After I did this the beep is played trough the PC speaker as if there is no soundcard and/or speakers present on the PC.
So now I'm looking for a way to get it back to play over the speakers using this external Soundblaster. I think it is a software/settings problem and even a simple one but I can't seem to find it.
@Enforcer: thanks m8, but that's not my beep. It's someone elses! I want my own beep back!
Old 09-06-2007, 01:24 PM   #5
Confusion Master
Enforcer's Avatar
It's roadrunner's beep.
maybe there is a a setting in the software that says which soundcard to use, I know winamp has, and for some reason it is stuck on the old soundcard even though it isn't there.
If there is no setting, uninstall drivers and reinstall and it may do a soundcard detection again.
Old 09-06-2007, 01:44 PM   #6
No, there is no setting to select another soundcard. The idea of removing and reinstalling the drivers isn't bad. Seems logical. Will give that a go (if I find the darn CD...)
Old 09-06-2007, 02:21 PM   #7
No luck... Removed drivers and installed new updated ones but my beep still stits in my PC and not my speakers.
Old 09-06-2007, 03:03 PM   #8
Arrow's Avatar
My software only gives me the option for a system speaker beep. I'd imagine the same holds true for most. I have seen motherboards that will play system beep tones through the onboard sound card. That's probably what you have going on. The sound will no longer play because the motherboard isn't designed to play the system beeps out of anything but the onboard speaker and onboard soundcard.
Arrow is offline   Reply With Quote
Old 09-06-2007, 03:33 PM   #9
Laptop, Tablets, UMPC Moderator
turbocad6's Avatar
I've seen a utility that beeps on mouse press, something like noisymouse or clickmouse?
there are software utilities for mouse clicks that can do what your after I think...
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 09-06-2007, 06:16 PM   #10
I found that noisymouse thingy. Will try it when I get home.
Old 09-07-2007, 03:35 AM   #11
That will be probably it then. Didn't know about that.
Ok, I've downloaded noisy mouse and installed it on the Car PC. I was a happy puppy for about 5 minutes. I had a nice "click" sound when I pressed my touchscreen. Even tried roadrunners "beep beep" to make enforcer happy but it gets annoying after some time...
Everything was dandy until I wanted to run iGuidance. The darn thing freezes when noisy mouse is running. Stand alone or in roadrunner, I've tried them both, but everytime iGuidance freezes. When I disable noisymouse, iGuidance works perfect. So I tried it on my desktop (running vista) and everyting works great. But I don't need a mouse that's noisy on my desktop, I need it on my Car PC.
So I downloaded your other option, mouseclick and tried it on my desktop. This is a complete mess. It begins to freak out on me from the moment I want to run it. Something with "0,0000 is not a valid floating point" and it sits there beeping in the lower right corner until Vista shuts it down automaticly.
So to make a long story short: Stil no beep!
Old 09-07-2007, 04:33 AM   #12
Clickmouse and also Mouseclick (yes they both excist) seem to be automouseclickers. So they click the mouse for you. Someting to avoid RSI. Not really what I need ...
Been googling for a while now and find nothing else except for noisy mouse and "sounding keyboard and mouse" but this is shareware and I'm not willing to pay 30$ for a program to get my beep back. It's also not very practical in use.
Noisy mouse was perfect but those stupid iGuidance problems.. Aaarrggghh!!
Why would it work on my desktop and not in the car?
Old 09-07-2007, 07:36 AM   #13
Confusion Master
Enforcer's Avatar
That'll probably be because you are using European settings where you have a comma for decimals rather than a fullstop.
modify monitor case w/o back Mike12086 LCD/Display 0 12-08-2006 10:04 AM
I'm back! How have you all been? J187 Road Runner 5 12-06-2006 09:58 AM
In the MP3 selection, I can use the forward button all the time, but not always back clean customs FP Bug Reports 4 03-23-2005 11:33 AM
USB HD enclosure has to be removed and plugged back in? knubile WinNT Based 5 01-03-2005 09:39 PM
