Notices
Old 09-15-2007, 07:41 PM   #1
tigergibb's Avatar
Help! Lilliput Touchscreen stopped working!
Well, I've been without my CarPC for 1-2 months now because when I installed some new switches, it quit working. I fixed it and it was simply some loose connections. I powered it back up and everything worked great! A few minutes later, after I restarted it, the touchscreen stopped working. I can see still everything on the monitor, but the whenever I touch the screen, it moves the curser into the bottom right part of the screen.
I took my fingernail and ran it across the edges to check for dirt/objects and there were none. It won't let me calibrate it. Whenever I try to, it doesn't do anything. It does recognize the touchscreen though.
Anyone know what's wrong or what I can check? This is less than a year old . $1000 in CarPC parts sitting there with no use.
Thank you, Daniel.
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 09-16-2007, 02:06 PM   #2
tigergibb's Avatar
I started it up this morning and this time it actually let me calibrate it. The calibration worked normally, but when it was done every time I tried to press something the curser disapeired. When I moved my mouse, the curser was in the top right corner.
Old 09-16-2007, 03:12 PM   #3
tigergibb's Avatar
I uninstalled the touchkit and drivers. I then installed the newest drivers/touchkit and it does the same exact thing. Whenever I try to calibrate it with the new touchkit though, it says The linearity is not correct. It then asks me if I want to recalibrate it. If I choose "Yes" it'll do the same thing. If I choose "No," it won't work at all until I calibrate it. It is going to the bottom left corner whenever I touch anywhere on the screen now.
Old 09-16-2007, 03:18 PM   #4
Neither darque nor pervert
DarquePervert's Avatar
Try loosening the case in that corner. IT's probably the edge of the bezel pressing against the touchscreen.
If that doesn't fix it, you may have a faulty touchscreen.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
FS:: 7" Lilliput touchscreen lcd carfreak01 Classified Archive 11 08-29-2005 12:47 PM
Lilliput touchscreen driver for custom linux distro immolo LCD/Display 5 04-29-2005 04:47 AM
Lilliput Touchscreen Problem BrUTaL LCD/Display 12 10-23-2004 11:52 AM
Blew dust off, searched, and still no touchscreen on Lilliput - help! TheSpatulaOfLuv LCD/Display 4 10-13-2004 10:17 AM
WTB Lilliput with broken touchscreen or Lilliput without touchscreen dettman23 Classified Archive 1 04-11-2004 09:12 AM
