Old 09-22-2007, 01:56 AM   #1
Boke my screen >=|
After hours and hours of bondoing and sanding I finally finished and went to put my screen back together and boom the little plastic clamp thing that holds the flat wires in place broke off. Now I have no way to keep the wires in place. I've tried to put it back on but it's broken and I've tried to tape it in place but doesn't seem to work. Anyone have any ideas? I know I'm not real descriptive I will take a pic of it tomorrow. I'm sure you know what I'm talking about though
04silvertib is offline   Reply With Quote
Old 09-22-2007, 03:10 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
It is the infamous white ZIF socket. The big ribbon correct? You will need to check mouser or PM Armen for a replacement socket. Then there will be quite a bit of soldering. If you cant solder, then you have a paperweight.
Old 09-22-2007, 03:57 PM   #3
Yes it is, I just went to push it down and boom broken. I was like wtf. I've soldered before but I can't say I'm good at it.
Old 09-23-2007, 02:01 PM   #4
If you've soldered before, but never on something as small as this connector, grab an old cdrom drive and practice on that first. They have similar connectors on the boards inside (actually...if you're lucky it may have one the same size).
If you're eyes aren't very good (I don't trust mine like I used to) then get one of those big magnifying lenses with the ring light around it, and use that to look at what you're doing. It's amazing how much easier it makes the job when it's magnified so much
nst6563 is offline   Reply With Quote
The absolute easiest way to make a windows boot screen..... polo6979 Newbie 14 09-11-2008 03:14 PM
Constantly removing the screen 7" lilliput advice steveb LCD/Display 10 04-17-2007 10:56 AM
Cracked Touch Screen! bmather9 LCD/Display 5 04-17-2007 04:31 AM
Non-VGA screen to VGA xxMIKExx LCD/Display 13 04-10-2007 09:18 PM
FAQ: LCD Technologies dontpntpool LCD/Display 4 03-15-2007 12:20 AM
