Notices
Old 10-01-2007, 02:57 PM   #1
LiquidKernel's Avatar
Any results from using a VGA duplicator/booster?
As soon as I added the VGA extension cable to my carpc the quality on the screen took a nose dive. I've gotten used to it, but I know it can be better.
There is an ATEN VS92A VGA signal booster for $30 on eBay (Buy It Now). I am wondering if this would be sufficient to reduce the signal loss I get?
They also have Belkin OmniView extenders for around $20. Seems like a cheap deal. There are a few that carry over cat5 as well (two units).
95 Volvo 850 T5 • Konis • ECU @ 17psi • 5+20% Tint • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • 2.5" BOSCH HID Projector Retrofit
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 10-01-2007, 03:50 PM   #2
marshallh's Avatar
That happens when you get crappy VGA cables. Basically, you get what you pay for. You're probably better off getting a high-dollar cable from a place like a network or audio supply place.
Progress:
[■■■■■■■■] 100%
Mitsubishi 3000GT car computer
Previous budget Honda carputer
marshallh is offline   Reply With Quote
Old 10-01-2007, 05:19 PM   #3
Yeah I got pretty cheap cables. What's the going rate for good VGA cables?
Old 10-01-2007, 07:55 PM   #4
i bought mine from a local computer store i work at... look for ones with good shielding, the only problem is that there so thick they are hard to bend and hide.
here is a website that seems to have the same one I have
http://www.vga-cables.net/premium-vga-cables-list.html
i700plus is offline   Reply With Quote
Old 10-01-2007, 08:00 PM   #5
before you buy more ****,
are you sure that maybe just one of your vga cables is cheap and not shielded enough?
maybe try a different VGA extension.
I extended mine and don't have any noticeable drop.
Snortonnorton is offline   Reply With Quote
Old 10-01-2007, 08:01 PM   #6
wha'ts funny is that the high quality vga extension was cheap at cirquit city, but the usb extensions are expensive as fuc*
Old 10-02-2007, 12:26 AM   #7
marshallh's Avatar
You should pay upwards of $20-30 for a good 6' VGA cable. Likely your problems will disappear when you do that.
Why are USB cables so expensive?? Because printers sell dirt cheap, and do not include a USB cable.... So you buy their $30 cable seperately so they makeup the loss on their printer.
Progress:
[■■■■■■■■] 100%
Old 10-02-2007, 03:05 AM   #8
That's actually the problem I think. I bought a cheap eBay cable for around $20 (25ft). It's fairly thick, much thicker than the one that came with the screen. It works great for a CRT monitor, but when it comes to VGA on an LCD, quality deteriorates right away.
I also have extra slack, much more than I needed. I'll try getting a shorter cable of higher quality.
Hardware Review: Provision 8" 16:9 VGA Touchscreen lightman The Review Palace 18 05-21-2007 05:45 PM
Laptop to Factory Nav Screen - VGA Detection Pin tejesh83 LCD/Display 2 06-14-2006 01:54 PM
VGA upgrade for TM-701L digitalww LCD/Display 90 08-01-2003 10:01 AM
Xenarc VGA or Composite GTPmp3PC LCD/Display 4 01-14-2003 11:15 AM
