Old 10-02-2007, 12:47 PM   #1
liliput input volyage problem
I ahve a 8" liliput touch screen monitir, i rigged it up in the car a few weeks ago using the ciggy connector and it worked fine. I have a power adaptor in my workshop that outputs the same volts and required current so i can test it satisfactorily on the bench. I have come to install the screen and all i did was cut off the ciggy connector and connect it to a 12v Acc feed and a good ground. No joy, i can not get the monitor working in the car at all.
i have checked the volts at the acc output and it is 12v engine off and peaks at 14 v when engine on. I checked the output at the connector and it is only showing 8v max. in the lead there is an eliptical box which i assume is a regulator. could this have broken in any way?
I cant understand why its only ouputting 8v
Regards
rev1richie is offline   Reply With Quote
Old 10-02-2007, 12:51 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
It could be broken. Try to bypass it if you have a bench power supply, you can at least eliminate where the problem is.
2k1Toaster is online now   Reply With Quote
Old 10-02-2007, 01:05 PM   #3
As i said if i use a 240v-12v psu it powers up fine. do i need to use this regulator?
Old 10-02-2007, 01:25 PM   #4
Neither darque nor pervert
DarquePervert's Avatar
Yes....
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 10-02-2007, 01:33 PM   #5
i'm using a DSX12VD power supply, can i tap off 12 v from the molex connector for the screen wihout affecting the PC?
Regards
Old 10-02-2007, 01:57 PM   #6
actually, running the screen off the 12v line from the PSU that's powering the PC is probably your best option. The 'egg' or regulator is a pain in the ***. I got mine to work with it, but got a LOT of noise. What I ended up doing is running a 12v and ground from my Opus up to the front and powering my screen from that. I did still get some noise/flickering on the screen until I provided a ground point closer to the screen rather than running the ground all the way back to the pc.
nst6563 is offline   Reply With Quote
Old 10-03-2007, 01:22 AM   #7
Had a email from support at mpegbox re this and they said it would be fine to power the screen from the psu, in fact there is a 12v spade output all ready .
thanks for all your input.
ITPS problem... Please help sebcorazon Power Supplies 0 04-23-2005 12:56 AM
Help in designing an input selector switch bcw55 Newbie 6 03-15-2005 12:07 PM
High Input and Low input got2liv4him Car Audio 0 02-10-2005 10:38 AM
Sony hu w/changer control input problem solved! GMpc General Hardware Discussion 0 04-23-2001 09:07 AM
can I use an amplifier for rca input?? sheriff General Hardware Discussion 1 03-23-2001 08:03 AM
