The MP3car.com Store
Thread Tools Display Modes
Old 10-05-2007, 01:26 PM   #1
mustanglou's CarPC Specs
My Photos: (2)
Lilliput touch-sensitivity flaking out
I've had a lilliput for a few months now and recently the touch-screen aspect as been flaking out.
Specifically, about every other time I start my car, the touch screen won't work.. The display still works but touching it has no effect. Often, this will go away the next time I start my car. Also, one time when the screen didn't work, I unplugged the power to the screen and plugged it back it and the touch screen worked! Although, I haven't tried it again to see if it is a consistent effect.
Other things I've tried that didn't work:
1. unplugging/replugging the USB connector to the computer
2. pressing the power button on the lilliput
3. trying different menu functions on the lilliput
Does anyone have any suggestions? It's weird that I wasn't having this problem before and that it's only intermittent.
mustanglou is offline   Reply With Quote
Sponsored Links
Old 10-06-2007, 05:48 PM   #2
DodgeCummins's CarPC Specs
DodgeCummins's Avatar
Vehicle: 96 Dodge Ram 2500 Cummins Diesel (turned up)
My Photos: (20)
Occasionally my computer (used to) boot up thinking the serial GPS was the mouse.
It was beyond flakey...My fix is I have a switch to remove power from the GPS. and then I reboot.
It happened about once every month or so.
current projects
DodgeCummins is offline   Reply With Quote
Old 10-10-2007, 02:19 PM   #3
My Photos: (2)
Strangely, if I turn off the display either just before or just after I shut off the car, the touch-sensitivity will work when I restart my car. The only weird part is that I have to manually turn the screen on again even though I've programmed it to auto power-on.
Sponsored Links
Trackbacks are Off
7" lilliput touch problem, or is it just me ? cyrax83 LCD/Display 6 09-16-2005 07:05 PM
Lilliput (FA801 8" Touch) problems - reversed touch optiks LCD/Display 3 08-18-2005 12:03 PM
Lilliput (FA801 8" Touch) problems optiks Input Devices 1 08-13-2005 12:13 PM
FS - (New) Lilliput touch screen replacement calvincbr Classified Archive 1 01-27-2005 10:12 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 10:36 PM
Sponsored Links
Ad Management by RedTyger
