Notices
Old 10-07-2007, 05:34 PM   #1
Exclamation Lilliput Touch Screen Issues
Ok well I have my screen powered and I went to test everything out before final install of everything. THe touchscreen is really off, I tried running the calibration a few times but when I touch the X in the bottom left hand side of the sceen, the mouse pointer goes to the top right. So I am noticing the arrow is always opposite I guess. I have the GL701-NP/C/T model. I just downloaded the new drivers and will try that out to see if it will fix the error. During installation did you check PS/2 driver to be installed? Wasn't for sure what that was. Should I not have selected that option? I've done some searching and no luck. Any help would be appreciated.
Btw my pc is an HP Vetra E-PC, very old but usable.
tkd_guy90 is offline   Reply With Quote
Advertisement Sponsored links
Old 10-07-2007, 05:43 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
If your touchscreen is USB, then no ont select PS2 connector. And the opposite thing is very common. Just calibrate it. When the X shows up, do the full 4 point clicks, then it will save the info and it will work.
Old 10-07-2007, 05:52 PM   #3
Ok thank you very much. Do I just tap the x repeatedly or touch & hold?
Old 10-07-2007, 06:15 PM   #4
2k1Toaster's Avatar
Touch and hold. It should beep when registered through the speakers
Old 10-07-2007, 06:17 PM   #5
Ok, Second problem. When I touch the screen, the internal speaker (usually for errors) beeps continuously while I touch the screen on the desktop. Any reason why it would do that ( still havent tried out newer drivers)
Old 10-07-2007, 08:00 PM   #6
There's an option in the software to disable the beep when you touch the screen
dyne is offline   Reply With Quote
Old 10-07-2007, 09:15 PM   #7
AHh thank you. I did find it eventually. Thanks to everyone for their help. Sorry for my noobness
FAQ: Touchscreens explained RedGTiVR6 The FAQ Emporium 1 07-21-2008 11:10 AM
Can't calibrate lilliput touch screen _wd LCD/Display 10 02-14-2007 11:10 PM
FS: Lilliput 619gl-70np/c/t 7" touch screen kingeorge36 Classified Archive 7 05-06-2006 04:52 PM
Xenarc Touch Panel on Lilliput Controller badandy4you LCD/Display 5 06-04-2004 01:54 PM
In-Dash 7" MOTOR TFT or Lilliput 7" Touch Screen JonX69 LCD/Display 2 03-06-2004 02:22 PM
