Notices
Old 10-21-2007, 01:07 AM   #1
Xenarc 700tsv won't turn on
I tried to turn my screen on after I put it in a case I made and it turned on but then white would creep up the screen. I looked at the ribbon cable and it must have got damaged. I bought a new one but when I plug it in, the screen doesn't even turn on anymore. The green light on the front doesn't even turn off after a while. Anyone have any suggestions on how to help?
CloakingHalk is offline   Reply With Quote
Old 10-22-2007, 02:16 PM   #2
anyone?
Old 10-22-2007, 08:20 PM   #3
muldrick's Avatar
Hmmm, check the voltage going into the monitor, make sure you have 12V.
I took mine apart, beat it up pretty good...and it still works.
The green light does not turn OFF? must be gettin voltage then.
Sounds like you might have messed up a board...double check that ribbon cable.
Wish I had a better answer...sorry.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 10-24-2007, 01:44 PM   #4
Ok tried to find to test the voltage to the monitor but I'm not getting anything. What wires should I test. The board is getting power for sure and I think the monitor is too. I cant be sure the monitor is getting 12 volts. Another thing I've found is one of the resisters is getting really hot. It might actually be burning something too. I cant be sure though. Also I have noticed the the green light might be dimming over a period of time. Does this bring up anymore ideas?
Old 01-14-2008, 06:52 PM   #5
I have the same problems with my Xenarc and have come up with nothing. My ribbon cable is also damaged and I was thinking that was the problem. I took a multimeter to the board and it is getting 12V. If it makes a difference I never had this problem until I pressed a little too hard on the corner of the enclosure and shattered the touchscreen. I replaced the touchscreen and I get ALL the same problems as CloakingHalk. Any advice is much appreciated.
BuckyWMU is offline   Reply With Quote
FS: Xenarc 700TSV controller Jackboot Classified Archive 34 03-13-2006 11:56 AM
FS: Xenarc 700TSV $250obo tejesh83 Classified Archive 4 02-12-2006 09:24 PM
Xenarc 700TSV and Gain 700TSV the same? thrmaln LCD/Display 9 02-10-2006 09:22 PM
Xenarc 700TSV Buttons..... Cheekz185 LCD/Display 1 07-11-2005 12:20 PM
Does XENARC 700TSV has remote? EluSiOn LCD/Display 21 12-20-2004 08:32 PM
