7" Dynamix (LinITX) LCD - white screen problem
I can't believe this happened. I have had this screen working for the last 10 months, albeit rarely installed in my car and as soon as I get everything working well the screen ends up malfunctioning.
I have removed all the electronics from the factory housing and have mounted them to a custom bezel in my Ford Focus. The screen was working perfectly installed in my car and then for some unknown reason, just started displaying a white screen which looks to be backlight only. The remote and front control buttons are unresponsive and the power LED does not illuminate. I can only get the white screen to go away once I disconnect power to it.
I removed the screen from my car and set it up on my test bench with the same outcome.
I have checked all connections (unplugging, plugging back in) including the riddon cable and it is all secure and undamaged. Nothing changed, no bumps or falls while the screen was in the car. It just all of a sudden stopped fuctioning.
I understand this can be attributed to a faulty controller board and I'll have to get it replaced. I bought this screen used off of the classifieds and have removed it from the factory housing so there will definately be no warranty.
I am wondering if I can get a replacement controller board (the ribbon cable is fine and installed correctly). This monitor is from Dynamix which is the same model of screen that LinITX used to sell. It uses the Hitachi-made LCD.
Is there anything else I can do?
Thanks.
