Notices
Old 10-31-2007, 02:42 PM   #1
need to replace xdxp070z touch panel. Where?
its been a while since i played with my carpc.
the reason is because i cracked my xdxp070z 7" touch panel when i tried to install it into my finished (molded and painted) bezel. after that happened i decided to put the project on hold.
now its time for me to get back into it.
i tried to look around but i'm not really sure what i can replace it with.
this is the screen i have:
http://cgi.ebay.com/Headrest-7-VGA-A...QQcmdZViewItem
anybody know where i can get a new touch panel that will fit and work like it use to?
thanks for all the help.
hopefully i'll get this thing running with all the bugs worked out before the end of this winter
95 Mustang 5.0
Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
80% done
Dan95five0 is offline   Reply With Quote
Old 10-31-2007, 03:09 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
Are you ceertain it's only the touch panel and not the LCD itself?
Touchkits are available from a number of sources, including http://www.digitalww.com
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-01-2007, 01:42 PM   #3
lcd is fine just the touch panel needs replacing
the only thing i can find on digitalww is http://www.digitalww.com/store/prodd...asp?prod=10080.
i'm not sure if its the same dimensions or if its even compatible with my monitor.
95 Mustang 5.0
80% done
Old 11-01-2007, 05:25 PM   #4
have you tried to contact Armen (the proprietor of DigitalWW)?
He will be able to answer that question.
My Worklog
Old 11-04-2007, 05:14 AM   #5
I've the same problem. Could you please let me know if you have found a replacement for the touch panel.
Rances is offline   Reply With Quote
Old 11-04-2007, 07:31 AM   #6
Quote: Originally Posted by DarquePervert;1136539
Touchkits are available from a number of sources, including [url
http://www.digitalww.com[/url]
Oh wait. That was me.
My Worklog
Old 11-16-2007, 05:17 AM   #7
I have seen that page already, all touchpanels are Out of Stock
http://www.digitalww.com/store/products.asp?cat=20
Old 11-18-2007, 01:04 PM   #8
i did a search on google and look what i found.
http://store.mp3car.com/category_s/76.htm
mp3car.com has them in the store LOL
havent checked to see if it will fit tho.
i also found out that it has to be a 4-wire resistive
95 Mustang 5.0
80% done
Old 11-19-2007, 06:02 AM   #9
I think this one can be used for Lilliput screens.
My screen has another connector. See picture below. It's also 4 wire. I guess I can modify the connector to fit, but I'm not sure if I can use the same driver.
Old 11-23-2007, 09:15 PM   #10
its going to be a while before i'm going to need to use my screen. i'm just about to start building the computer now.
if you end up using this screen, let me know the results.
95 Mustang 5.0
80% done
Old 01-10-2008, 01:05 PM   #11
any results yet?
its coming close for me to need my screen so i can install it in the car.
95 Mustang 5.0
80% done
Old 10-20-2008, 01:08 AM   #12
Just Replace it?
i was thinking of purchasing this very monitor here-
http://www.chinavasion.com/product_i...-chip-vga-usb/
for $130 it seems like you could just buy another.
DutchBalls is offline   Reply With Quote
SP-716,DWW-700M,MTS12000 replacement touch panel onlineamiga LCD/Display 3 11-05-2006 04:13 PM
Digital World Wide Touch Panel Kits (6397) CfdRescue910 LCD/Display 4 07-27-2005 12:14 PM
Xenarc 700TSV Touch panel broken zaid175 LCD/Display 2 07-22-2005 04:18 PM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
