Old 11-01-2007, 11:31 PM   #1
Question Flip out or regular monitor
Ok all I need some advice I am finally home and ready to start my first carpc project and I need some help on deciding wether or not to use a flip out vga monitor or a regular monitor. I have a 2004 Durango my Dash can except a double din unit so with my measurements I can go up to a 9 inch monitor with out making serious mods to the dash but I just need some help deciding on which way to go I already have a kicker 1200 watt amp and a 1 farad cap and two 12inch subs installed so I was thinking to save some room so that I would not have to run another amp to just get a flip out with an amp already inside but I like the way most of the members here have gone with the clean look and installed a regular monitor for the clean factory look but the problem with that is I would have to buy and take apart a monitor and rewire it for the power and vga which seems from my reading here a little complicated so i would greatly appreciate some input from some people here who have already finished there installs. thanx
BIGGKATT01 is offline   Reply With Quote
Advertisement Sponsored links
Old 11-01-2007, 11:49 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
Motorized always fail, they look cheap, and have too much bounce when you touch them. Also if you are any type of audiophile the built in amp sucks *** anyways.
Get a regular screen. 8" 4:3 is a good big standard size you can mold in. They come with cig. lighter adapters already. So just run 1 more wire from the battery for it, and then 1 more for the PC. And if you have the cap because of "dimming lights syndrome" you need to fix that too with bigger guage wire.
Old 11-02-2007, 12:16 AM   #3
Thanx I am running alot of power I am running a 0 guage wire now I guess I will have to find some place to put another amp i already have a flip out dvd in the dash n ow its been in for ab out 9 months since i got the truck and its working out fine but i guess the only reason I wanted to go with a flip out is becuase of the wiring a regular monitor dont want to fry anything
Old 11-02-2007, 12:25 AM   #4
pRoFiT's Avatar
The wiring of a 12volt vga monitor is easy. 12 volts, vga cable and maybe USB if you go touch. Most of which you dont have to do anything too. Should almost be the same as a flip out screen. Except a remote turn on may be needed.
Worry more about molding it into the dash. And how big a screen you will be able to fit in there.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline   Reply With Quote
Pros and Cons of using a regular monitor? HiJackZX1 General Hardware Discussion 4 08-29-2007 01:02 PM
Does anyone ever mod. 7' monitor w manual flip to insert the Disk on 2 Din ? calico General MP3Car Discussion 1 12-31-2005 01:48 AM
CarPC Gets BLACKOUT! when monitor is connected! Sympotonic General Hardware Discussion 25 12-08-2005 03:30 PM
Dual Monitor Support. Specific Qs maxxell General Hardware Discussion 0 04-18-2005 09:38 AM
Running windows with no monitor? BLACKOUT General Hardware Discussion 14 03-14-2001 10:56 AM
