Old 11-02-2007, 06:51 AM   #1
initiale's Avatar
LCD touchscreen - anyone know this item?
http://www.sandecell.com/?item=PT%2D718TS&VID=1
Is it good for carpc? I mean I cant find any description about this monitor esspecially for does it have a VGA port?
initiale is offline   Reply With Quote
Old 11-02-2007, 07:28 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
No VGA port, only RCA composite. Image quality will suffer as a result.
Also, the touchscreen won't work with a PC.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-02-2007, 08:09 AM   #3
initiale's Avatar
Well I'm very sad to hera that, it has a very good price.
Old 11-02-2007, 09:19 AM   #4
walstib's Avatar
For $45 more you can get an 8" here
Carputer Project Status:
0% - Mobo died on 2/17/08
Check out the worklog for my '01 Pathfinder.
walstib is offline   Reply With Quote
Old 11-03-2007, 07:13 PM   #5
MitchellO's Avatar
$899 retail price my *** :P
MitchellO is offline   Reply With Quote
Old 11-06-2007, 10:50 AM   #6
initiale: don't skimp, you'll just have to spend the money again. You can get a 7" touchscreen VGA no name brand for under $200 (check ebay). Composite is not an option if you intend to be able to read text.
EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
mgithens is offline   Reply With Quote
Old 11-07-2007, 10:08 AM   #7
that's a piece of crap!!
1440x234 resolution is a lie, a "dot" on a monitor is actually three dots = Red, Green, Blue... the 1440 is 480 times 3... so this is 234x480... don't expect text to be legible, I mean even subtitles. 234 lines of resolution is less than VCR quality, less than your tube tv...
the MINIMUM is a 480 line monitor, with VGA input - otherwise it is ONLY good for video playback. No navigation and you won't even be able to read the file names without blowing the text up 10X...
http://cgi.ebay.com/Lilliput-EBY701-...QQcmdZViewItem
this monitor is $190 shipped... name brand, VGA, touch screen... would you really try to save $70 on something that is guaranteed to be crap??
FS: K90 In-dash LCD Touchscreen Monitor jwoznack Classified Archive 7 05-14-2006 03:22 PM
modded 10.4 LCD + touchscreen markopolo311 Classified Archive 22 02-28-2006 12:22 AM
FS Sharp 5.7 inch B&W Touchscreen LCD Kubla Khan Classified Archive 0 11-27-2004 12:43 PM
FS: My 10.4" Touchscreen LCD setup $195 shipped MeanGT Classified Archive 4 03-09-2004 01:46 PM
