Old 11-03-2007, 08:33 PM   #1
Question Do the lilliput GL701-NP/C/T have a brake wire
Can anyone who has the lilliput GL701-NP/C/T installed in there car tell me if it has a brake wire, I mean does it have to be wired the the emergency brake to operate. thanx in advance for any help
BIGGKATT01 is offline   Reply With Quote
Advertisement Sponsored links
Old 11-03-2007, 08:52 PM   #2
No brake wire on mine. I do have a reverse back up light wire so that when the car is put in reverse the lilliput switches over to my reverse camera.
The only thing that I have that utilizes the brake wire is my remote car start system.
I did have a wire on my lilliput labeled "NE" I did not connect it to anything and mine works fine.
Not real sure what it is though.
andyman is offline   Reply With Quote
Old 11-03-2007, 09:18 PM   #3
thanx for the info andyman i was thinking of getting one for my sytem because I just dont feel like going through all of the headaches it will take to do a regular monitor install like getting another amp and having it wired to my speakers. also how is the built in amp with this unit is it ok i mean does it power your speakers alright I mean sound wise. thanx again
Old 11-04-2007, 12:28 AM   #4
it does ok
I am not big on the sound system area. I mainly got the carpc for the pc part.
The radio quality is ok, but my sound standards are pretty low.
If you like really good tunes I would suggest going with an additional amp.
I have some line noise, but I think I can use a ground loop isolator to clear it up.
It's decent, but not much thumping going on for sure.
good luck.
My main problem with my setup is the usb ports not comming back after hibernate.
Working it out I hope soon.
Old 11-04-2007, 01:14 AM   #5
thanx for the response and help andyman its much appreciated.
[CoupeE46] BMW E46 2001 330ci CarPC ... CoupeE46 Worklogs 54 10-02-2008 07:16 AM
buy Lilliput GL701? mrborrie LCD/Display 10 07-15-2007 12:26 PM
400watt Power Inverter connected to Battery.. what wire is needed? joeapro Newbie 7 02-08-2007 03:39 PM
Looking forward to get the DC-DC PSU and now... cwho122 Newbie 11 03-09-2004 09:59 AM
ignition wire for opus psu liquid_smoke Power Supplies 3 09-09-2003 10:58 PM
