The MP3car.com Store
Thread Tools Display Modes
Old 11-26-2007, 03:38 AM   #46
My Photos: (0)
when it powers up...
the unit displays a menu so we choose on screen the working mode? Or is it possible to preset it in PC mode so when PC powers up the screen shows instantly the Windows environment? I'm thinking to use the Blaupunct head unit for FM RADIO and also drive the PC audio output through aux in. So i'll have always the Xenarc starting at PC mode (if possible) and can use the PC while listening to radio. When need pc audio output i'll switch to head unit's AUX LINE. On the other hand this complicates the DVD playback cause there will be no audio connection to Xenarc.
I consider buing it just for the easy DVD and USB connectivity.
jks13 is offline   Reply With Quote
Sponsored Links
Old 11-30-2007, 05:53 PM   #47
My Photos: (0)
is there anyone know what is parking brake wire for?
LSIMONZZ is offline   Reply With Quote
Old 11-30-2007, 09:28 PM   #48
FTWRUBI's Avatar
Vehicle: 03 Jeep Rubicon
My Photos: (3)
the parking brake wire is so that you don't mess with it while your driving. a safety feature.
FTWRUBI is offline   Reply With Quote
Old 12-01-2007, 12:02 PM   #49
bl3nd3r's Avatar
Vehicle: 2000 Ford Focus ZX3
My Photos: (10)
Quote: Originally Posted by JackB View Post
I decided to install my unit over the holiday break and I realize I don't have the drivers for the touchscreen? Anyone have a link to them? The Xenarc site doesn't seem to have them up that I could find.
I also had this problem and emailed up tech support. They emailed me back very quickly with this link for the drivers: http://www.xenarc.com/driver-touch1.html. Hope this helps.
bl3nd3r is offline   Reply With Quote
Old 12-03-2007, 11:13 AM   #50
My Photos: (0)
Are these units like past units I've installed where you ground the parking brake wire and it works at all times?
elimenohpee is offline   Reply With Quote
Sponsored Links
Old 12-03-2007, 12:59 PM   #51
My Photos: (0)
Hooking up the P-break to +12V will do that, yes. That may or may not be what I've done depending on the local laws in the area that I live.
JackB is offline   Reply With Quote
Old 12-04-2007, 02:06 PM   #52
My Photos: (0)
Parking-brake goes to 12v? I always though it was connected to ground. I need to find out which before I hook something up wrong and it blows up lol.
Old 12-05-2007, 04:11 PM   #53
My Photos: (0)
I contacted xenarc, the parking brake wire is only to prevent you from using the dvd player while driving. But he said to bypass it just ground the wire.
Also I was able to pick this up off ebay from dynamix for only $650 (submitted an offer), a lot more reasonable than the $800, plus not a bad deal considering what you are getting. Just a fyi.
Old 12-07-2007, 07:53 PM   #54
My Photos: (0)
Hey this is probably a dumb question, but does anyone know how to get the harness for the speakers out of the back of the unit? It's clipped in, but I can't see how to get it out.
Old 12-08-2007, 07:29 PM   #55
My Photos: (0)
thanks people answered my previous question about parking brake wire for, i connected it to ground and it work.
i have another question where can i connect the 22. wire remote and 23. ant&amp remote control?
is the power antenna same as wire remote and the AMP turn on same as ant amp remote control?
Old 12-09-2007, 10:39 AM   #56
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
Quote: Originally Posted by kickercivic1 View Post
The price is too high.. I will get this right away if it was close to $600
Most car audio units of this magnitude run $1000+....
Quote: Originally Posted by Cheekz185 View Post
The screen can automatically open and close with the ignition.
I don't believe this is the case. The unit I recieved for testing did not do this...quite annoying.
What about rca outs for front/rear and sub?
Pair for Front, Pair for Rear, mono for sub
Quote: Originally Posted by LVExpo View Post
but what i don't understand....one rca subwoofer out??? isn't it usually a pair of cinch??????
Sub-bass is almost always a mono-signal. Only in high end solutions do you have stere sub-bass.
Quote: Originally Posted by linkyone View Post
I am huge on audio quality and sound control. i have a Pioneer Premier hu now and 2 amps for my sound system. all the crossover and EQing (15 band) is done in the headunit. what kind of eq and or cross over system does this hu have? are there any instruction manuals that have this info?
No xos. Only a 7 band EQ.
Quote: Originally Posted by jlindeman View Post
Also, the radio doesn't power on automatically when the truck starts. It lights up around the power button, but you actually have to power the unit on ( I need to figure that out as well). I even had it professionally installed so i think it is a setting
If you find it in the settings, post it up, I could not find it. In most other car audio pieces, its a setting.
Ohh.. and the volume... there is a weird delay, you have to adjust the volume and then click once more to make it go to the desired level. if you are looking for instant feedback, you have to adjust SLOWLY... weird.
I noticed this as well. It's not speed dependent. If you turn it FAST it still just changes the volume a notch or two at a time...same as if you turn it slowly. If you wanted/needed to quickly ramp up or ramp down volume, you're SOL.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 12-09-2007, 10:54 AM   #57
_
My Photos: (73)
Quote: Originally Posted by bl3nd3r View Post
I got mine on Friday night and seem to be having a problem with the DVD drive. It won't suck in the CD/DVD until it is basically all the way in 3/4 or more. From the drives I have worked with in the past usually they take the DVD/CD after you have inserted it less then 1/4 of the way. Can any other owners of this unit comment on this?
The DVD drive for DVD functions doesn't work unless you are on DVD mode. This is outlined in the manual...it's quite strange if you ask me. It should have the ability to auto-switch. Every other Car Audio piece out there does.
Also anyone know what exactly the right knob controls? It looks like radio maybe, but I can't tell.
It's like a joystick for navigating the various screens. The touch screen can be used as well. It's pretty delicate. The unit I recieved had this knob on upside down....it fell off in my hands and will need to be superglued back in place to ensure it doesn't happen again.
The unit doesn't power on by itself in my Truck (Hummer H2). It does shut down with ignition but when I start the car, the standby light (?) comes on on the deck but it doesn't power on- I have to do that manually. Maybe its a setting somewhere that I haven't found.
Again, I haven't found this either.
Quote:
I figured out how to set the presets on the radio, weird combination of pushes of frequency and preset buttons.
Would you mind posting up how to set a preset? It's not documented in the manual IIRC...though it should be.
Quote:
I have had to disconnect the battery once since getting it. playing with menu- it locked up and wouldn't shut off- no matter what. I have not been able to recreate this.
This happened to us as well. We got in the truck, the turned the unit on, and it was at 3/4 volume, NOT on the same radio station that we were listening to previously (annoying) and the screen was black. I couldn't adjust the volume, I couldn't put the screen back in, I couldn't turn the unit off, I couldn't do anything. We had to pull over and pull the fuse (btw - you shouldn't have to physically disconnect the battery, just pull the fuse.
Quote:
The volume delay for the unit is annoying in my opinion.
I agree, 100%.
Quote:
The fan on the unit cycles on and off, so it doesn't stay on all the time but it isn't silent by any means. It sounds like your defrosters little brother on #3 fan setting.... It's not annoying, and isn't really noticeable when music is playing though.
It's abnormally loud, ESPECIALLY considering it's not a PC that it's having to cool....no other car audio head unit I've ever had has been even close to this loud. This is something they will need to take care of if they hope to compete on that level.
The fact that it doesn't automatically turn on when you start the car is a turn off. Can anyone else confirm it doesn't do it?
Yeup - confirmed.
Quote: Originally Posted by 2k1Toaster View Post
NC normally stands for No Connect. I would say it is a safe bet if the manual doesnt mention the wires.
The manual labels them. If they were smart though, they would at least state this in the manual. It would help cut down on their support time since I'm sure they will have a LOT of people emailing/calling asking about them.
Anyone know how long that usb, dvi, and vga cables are? I can't tell from the manual or the few pics I've seen.
They are just pig-tails. They are not designed to be the only cable between your unit and the PC. How they did this though is a lot smarter than some of the others out there. The unit is already very deep. If they hadn't have made these on pig-tails, the unit wouldn't have been able to be installed in any vehicle since no vehicle would have the depth avaliable.
[quote=LSIMONZZ;1150704]i have another question where can i connect the 22. wire remote and 23. ant&amp remote control?
Ant. + amp remote are all the same. Just connect this one wire for your amp turn on.
wire remote wire is not documented...unless it's a secondary remote turn on...
Jan Bennett
Old 12-09-2007, 03:29 PM   #58
Cheekz185's CarPC Specs
Vehicle: 2002 Mitsubishi Galant
My Photos: (0)
Hey Red... I was just wondering I know this is a BIT off topic but... would you recommend this unit? Granted it does not look as sleek and stealth as a molded xenarc screen. I currently have a 700tsv molded into my dash but I have how i have no radio...And i dont wanna but an addon radio for a pc... i kinda wanna go back to the stock look...
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 12-09-2007, 11:55 PM   #59
Stonewall78's Avatar
Vehicle: '99.5 VW Golf TDI
My Photos: (0)
Anyone have any idea what voltage the audio pre-outs are? I am interested in this unit but for the money it better well be at least equal to the quality of a entry level DVD player.
Stonewall78 is offline   Reply With Quote
Old 12-10-2007, 08:30 AM   #60
_
My Photos: (73)
Voltage outs was one of the things I was going to test. However, I believe my unit to be defective based on the number of issues I'm having so I pulled it to return it before I had a chance to test it.
Jan Bennett
Sponsored Links
vB code is On
Trackbacks are Off
Xenark 700TR flip down VGA washed out! palpatine LCD/Display 7 06-01-2006 02:06 PM
Xenarc Announces their 700IDT In-Dash Monitor Morgon Input Devices 12 02-15-2005 01:29 PM
VGA capable monitor needed for XBOX? is300 LCD/Display 4 02-14-2005 07:23 PM
WTB: XENARC 700TSV™ 7" TFT LCD Monitor w/ VGA & Touch Screen bd3521 Classified Archive 1 01-22-2005 08:03 PM
Xenarc 7" Touchscreen VGA Group Buy. Skippman LCD/Display 144 07-27-2002 10:52 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
