The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 11-10-2007, 02:48 AM   #1
Vehicle: 04 BA XR8
My Photos: (0)
remove lcd overlay?
can you remove the touch section of a lcd touchscreen and use it by itself? Or put it on another screen? Cheers
toymachine is offline   Reply With Quote
Sponsored Links
Old 11-10-2007, 03:03 AM   #2
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
yes
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 11-10-2007, 10:20 AM   #3
Vehicle: 2000 VW Jetta VR6
My Photos: (3)
and make sure you take the controller too.
EPIA TC 1G 256MB 60GB Linux,WindowMaker, Roadnav, Xine, XMMS, iGuidance3
Lilliput 8", Pharos i360, WUSB11v2.6 WiFi
dupa2 is offline   Reply With Quote
Old 11-11-2007, 07:55 PM   #4
Vehicle: 04 BA XR8
My Photos: (0)
righto, its just that i might be buying a lcd that got fried (no fuse and something went up in a puff of smoke, is the description ive got) haha i havent seen it :P its 7"
so yeah i was thinking of taking the overlay (and controller) and putting it on top of my 6" screen and hiding the excess... so can i calibrate it down to a 6" screen...???
Old 11-11-2007, 08:12 PM   #5
nobb's CarPC Specs
My Photos: (14)
I dont know about other screens, but for my k301, it seems that the touch controller is embedded in the circuit board which also handles the lcd functions. So keep in mind that the controller for the usb might not necessarily be a separate entity that you can just pull apart and use.
nobb is offline   Reply With Quote
Old 11-11-2007, 09:45 PM   #6
Vehicle: 04 BA XR8
My Photos: (0)
righto...i know its a bit ambiguous, let say this screen has had too much power fed into it and blown.... what would go....some sort of power supply...? is the power easy to fix... understand if its too left field without any info :P
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Should I remove LCD from casing or use the bezel? xraycat Fabrication 0 03-31-2007 12:00 PM
Sponsored Links
Ad Management by RedTyger
