Old 11-11-2007, 06:25 AM   #1
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
vga and dvi usage
this may be the wrong place for this question, so mad please move as necessary.
the question.
i have on my computer a vga output and a dvi output,now not knowing anything about dvi i persume its a better video output. but as i have both on my comp. can i use them for dual monitor.
by either buying a
1.dvi ts screen and a vga screen
2.vga ts screen and a dvi screen
3.convert dvi to vga adaptor then a vga to rca cable
4.vga to rca cable on vga and use a dvi ts screen
the idea is i have 2 standard rca screens and i want to put 1 in the back of the car and the ts in front.
thanks
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 11-11-2007, 07:54 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Moved to LCD/Display, since netiher VGA or DVI are Input Devices.
It really depends on the video chipset on your motherboard or video card. If it can output to both the VGA and the DVI outputs at the same time, then yes.
Consult your owner's manual.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Depth of Mini w/ DVI to VGA Adapter nvrau MacCar 8 09-06-2006 08:13 AM
DVI vs. VGA cables ŠuTcH LCD/Display 1 11-15-2004 11:32 PM
DVI -> VGA Fox_Mulder LCD/Display 2 11-15-2004 12:16 AM
Source for lond DVI & VGA cables. TheSpecialist LCD/Display 6 02-23-2004 11:34 PM
