The MP3car.com Store
Thread Tools Display Modes
Old 11-13-2007, 01:01 AM   #1
Salmizar's CarPC Specs
Salmizar's Avatar
Vehicle: 04 Chevrolet Colorado
My Photos: (0)
Question 2008 Xenarc 700TSV 800x480 problem
Hey,
I have a 7' screen as mentioned in the title with a Intel little valley board which supports 800x480. When I place the board at this resolution regardless of the color depth, the Xenarc always recognizes it as 800x600, causing obvious undesired results. All other supported resolutions function as they should.
Thanks to this forum I have successfully designed, implemented and troubleshooted every problem I have had so far, this problem finally problem however I have not been able to find an answer too.
Anyone else experience this problem? Thanks!
Salmizar is offline   Reply With Quote
Sponsored Links
Old 11-13-2007, 01:04 PM   #2
My Photos: (0)
Same problems here..
I used powerstrip with every 700tsv setting i can find.
Only difference is that my screen says it's 852x480 or 640x480 (depends on the version of the settings).
stavrosg is offline   Reply With Quote
Old 11-13-2007, 02:02 PM   #3
VmtSquad's CarPC Specs
VmtSquad's Avatar
Vehicle: 2004 / Acura / TL 6sp Dyanmic
My Photos: (100)
I also had some issue with my 2008 tsv screen but it was mostly related with the touch screen drivers....I went with an older driver and that fixed the problem.
I don't have that resolution problem, but I realized that it could be a PIA to configure sometimes.
If you guys find a solution!! LET US KNOW
VmtSquad - I sold my soul to Honda!
CarPC progress: 15%
VmtSquad is offline   Reply With Quote
Old 11-13-2007, 10:51 PM   #4
Salmizar's Avatar
My Photos: (0)
Thanks!, Do you happen to know the version of the driver you were successful with? Also I would never think the two (driver and resolution problem) could be related to each other, how did you stumble upon it?
Old 11-15-2007, 12:10 AM   #5
My Photos: (5)
what's the advantage of running at 800x480 vs 800x600. Most FEs and skins can handle either one fine without the image appearing stretched..
hari-bhari is offline   Reply With Quote
Old 11-15-2007, 01:03 AM   #6
Salmizar's Avatar
My Photos: (0)
The only reason I wanted to try 800x480 was to see the true clarity of this monitor. And curiosity, otherwise I am happy with 800x600.
Old 11-15-2007, 09:35 AM   #7
My Photos: (0)
lol.. me too.. clearer, and probably a hair brighter.
Stav
Old 11-15-2007, 10:08 AM   #8
My Photos: (0)
Probably same chipset as the "new" 700IDT
I ran into this problem when I bought the "new version" of the 700IDT. Long story short, they changed the chipset so "native mode" is actually not supported. I told them they should change their specs since they claim that the displays will support 640x480 thru 1600x1200 but that is technically no longer true :-/
No driver or timing adjustments will fix this. This is a hardware issue...
dharris2112 is offline   Reply With Quote
Old 11-16-2007, 09:06 AM   #9
My Photos: (0)
figured.. tried everything..
Sponsored Links
vB code is On
Trackbacks are Off
800x480 w/ VIA M6000 & Xenarc - no DDC Channel Camryputer LCD/Display 0 10-01-2006 10:45 PM
Xenarc 700TSV 7'' touch screen krazymarine Classified Archive 3 09-20-2006 10:55 PM
Strange problem powering xenarc from 90w Opus :( Brettster LCD/Display 3 05-11-2004 05:19 AM
Has anybody got 800x480 to work with ver2 xenarc? ChrisC LCD/Display 4 10-25-2003 04:28 PM
More info on 800x480 mode for Xenarc... InFix LCD/Display 8 08-27-2002 08:54 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
