Old 11-19-2007, 12:38 AM   #1
Curry is on a distinguished road
Problem with lilliput!
Ok so I've been running my lilliput for a while now and just the other day I turn the computer on and it tells me "Out of range"
No problem... Change the refresh rate to different ranges.. I finally get display with 60Hz but the screen flickers! I tried 75+ Hz but it just gives me "out of range"
All the other ranges give me "Out of range" and 60 was the only option left...
I tried another AGP card but nothing is working... Im starting to think there s a problem with the screen it self or one of the wires..
anyone else experience this? what should I do?
Sorry forgot the model number, ill post it up later.
1999 Lexus GS300- (going VIP)
1993 Lexus SC300-Turbo (Totaled by idiot driver)
1996 Lexus SC400- (Totaled by brother)
1972 Datsun 240Z- (WIP)
1994 Toyota Camry- (sold)
Curry is offline   Reply With Quote
Old 11-20-2007, 07:23 PM   #2
Ok so after fiddling with the screen for a while here's what happened.
I plugged the carpc into my home LCD and I got it to display 800 x 600 @ 75hz without any problems.
I disconnected my home screen and connected the lilliput and i was getting a display @ 800 x 600
After I reset the computer (Lilliuput attached) I get the windows splash screen and after that it goes black and says out of range.
I plug in my regular home PC lcd and it displays fine!
I changed the resolution on my carpc to 1024 x 768 and plugged in my lilliput and restart, it boots up fine and i can see everything...
It appears the problem is when I go into 800 x 600 mode... no refresh rate seems to work..
Anyone have suggestions...?
The Graphics card is an ATI Radeon 7000VE
Old 11-20-2007, 07:54 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
This seems to be becoming a popular problem. I myself had this issue. If changing the refresh rate doesnt work, the screen has died. You must use a different resolution. I made a similar thread here: http://www.mp3car.com/vbulletin/lcd-...io-ts-lcd.html
Just switch to 640x480 or 1024x768 and be happy. There really isnt anything that can be done.
Old 11-20-2007, 08:03 PM   #4
I just came across that thread after changing my search terms. I ended up caving and im sticking with 1024 x 768
Good thing for that thread, I was about to toss this thing out the window.
Thanks!
Lilliput TS problem. FunkDaMonkMan LCD/Display 1 12-15-2006 06:15 PM
Mac Mini and 8 inch Lilliput USB Problem..HELP! shreddie MacCar 7 04-18-2005 01:41 PM
Lilliput Touchscreen problem DookieGraphics LCD/Display 7 03-24-2005 03:33 AM
Help solve my resolution problem on my 7" Lilliput!! CDL0012 LCD/Display 0 06-15-2004 12:01 AM
