Old 11-24-2007, 03:13 AM   #1
DarkMastyr's Avatar
DarkMastyr is on a distinguished road
Xenarc 700IDT not turning on, did I short it out?
Hi there. I recently installed my Xenarc 700IDT. It worked perfectly fine on the bench with a regular computer power supply, but it does not want to turn on when hooked up to the car. I have it drawing power from my M2-ATX, with the remote turn-on wire spliced into a 12V feed on my headunit. A test of the voltage at the monitor harness input shows voltages of between 11-12V for both the turn-on and power lines.
One thing I accidentally did was I touched the negative of the harness to an active +12V line from the car and I noticed some sparking. Did I short something? I checked the fuse on the positive line, but it seems to be fine.
Does the turn-on signal absolutely need 12V, or would something a little less (>11V) still work?
I would really appreciate some input.
DarkMastyr is offline   Reply With Quote
Old 11-24-2007, 04:34 AM   #2
PORTUGAL's Avatar
PORTUGAL is on a distinguished road
I have it conected directly to the 12v of my car and still today works flawless.
I was going to conect to my opus , but im lazy
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
PORTUGAL is offline   Reply With Quote
Old 11-24-2007, 07:31 PM   #3
DarkMastyr's Avatar
Alright well I figured out my problem. Apparently there was an issue with some of my power lines and even though they read 12V, they weren't sending any current. I spliced into my ciggy lighter instead (don't like using the bulky adapter), and it works fine, except the rear connector is finnicky as hell and I can't push the monitor all the way into the dash without the connector coming loose and generating all sorts of signal issues.
Xenarc 700IDT No Image, ribbon cable slightly cut! Help! *Pics* gotrice05 LCD/Display 1 11-17-2007 08:30 PM
XENARC 700IDT vs Lilliput GL701-NP/C/T KRS_Juan LCD/Display 3 06-07-2007 09:46 PM
FS: Xenarc 700idt $250OBO CJ8501 Classified Archive 1 12-05-2006 01:15 PM
Trade Xenarc TSV for Xenarc Xenarc 700IDT msreyes Classified Archive 4 06-20-2006 01:13 AM
Xenarc 700idt DrkStormTrooper LCD/Display 3 06-01-2005 08:40 AM
