Old 12-01-2007, 03:35 PM   #1
dacho is an unknown quantity at this point
New xenarc 700tsv touchscreen moving around
As I stated in the title I just received a new xenarc 700tsv and it looks really good however, touch screen mechanism moves up, down, left and right for couple of mm. If I push it all the way up and calibrate it, then pull it down and check the calibration I find out that it is off by a distance equal to the movement it made. Now my question is does anyone else experience this or how normal is this? Also should I just send it back for a replacement. Thank you
dacho is offline   Reply With Quote
Old 12-01-2007, 10:39 PM   #2
cdcamaro9534's Avatar
cdcamaro9534 is on a distinguished road
It could be fixed but you would have to open it to do that. Since its under warrenty I'd just send it back. I sent my 700IDT back twice when I bought it new before they got it fixed right.
1995 Chevy Camaro
VIA EPIA M10000 Mini-ITX Motherboard
WD80 Hard Drive
WinTV Tuner
Iguidance GPS
Road Runner Frontend w/ Liquid Smoke's skin
Xenarc 700IDT with DVD CDR/RW
cdcamaro9534 is offline   Reply With Quote
Old 12-02-2007, 07:11 AM   #3
lbridges is an unknown quantity at this point
There are 4 screws internally that act on little metal strips to clamp the screen elements to the face frame. Sounds like they weren't tightened enough - or perhaps overtightened and stripped out - in either case if it's under warranty, it needs to go back.
lbridges is offline   Reply With Quote
Old 12-02-2007, 03:03 PM   #4
Thanks guys, I will send it back then.
Xenarc 700TSV Doesn't Fit zzzBrett LCD/Display 7 01-30-2007 03:13 AM
Xenarc 700TSV 7'' touch screen krazymarine Classified Archive 3 09-20-2006 11:55 PM
Pandora w/ Xenarc 700TSV and Barrel Connector froalskiner General Hardware Discussion 7 07-20-2006 03:39 AM
FS: Xenarc 700TSV 7" Touchscreen VGA LCD Monitor fraganic Classified Archive 13 06-19-2006 08:24 PM
FS: 7" Xenarc 700TSV TouchScreen qjones Classified Archive 11 09-02-2003 09:28 AM
