The MP3car.com Store
Thread Tools Display Modes
Old 12-19-2007, 07:25 AM   #1
My Photos: (0)
Lilliput+Via Epia @ 800x600 = Newby aspect ratio question
Hi All,
Still slowly working on gathering my carPC pieces, so I don't have it all together yet. I was going to wait until I was done and see for myself, but curiousity is getting the better part of me, so.....
Since the Lilliput's are 16:9 (or 15:9 not sure) aspect ratio monitors, and the Epia's do not have any widescreen resolutions available, my question is, basically how does the aspect ratio work out?
Does the front end take care of making sure videos and such aren't stretched?
I am probably not explaining myself very well; let me try it like this. If you have an old PC with only 4:3 resolutions available, and you hook it up to a widescreen monitor, no matter what res you select, the icons, text, etc will all be stretched horizontally, which means the movies make people look "short and fat". Sometimes the stretching isn't obvious, but its there. Does the front end fix this?
Thanks,
-Alan
FirebirdTN is offline   Reply With Quote
Sponsored Links
Old 12-21-2007, 06:37 PM   #2
Lazyflip's CarPC Specs
Lazyflip's Avatar
Vehicle: 2002 VW Jetta 1.8T
My Photos: (12)
I know the VIA EPIA CN13000G is capable of widescreen resolutions. I'm not sure about the other front ends but I know Streetdeck will correct the aspect ratio of the videos you watch depending on what resolution you are using wether it be 16:9 or 4:3.
02' JETTA 1.8T | WORKLOG ALBUM
Lazyflip is offline   Reply With Quote
Old 12-24-2007, 10:22 AM   #3
VettePC's Avatar
My Photos: (0)
Anyone have some good info on this? I am using the Lilliput and its 15:9 (think its 800X480)
Using DFX2.5
What do I set the resolution on the PC to AND in RRConfig.exe?
VettePC is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
epia m10k + lilliput => gps blocker? NaFooEsi GPS 28 04-12-2008 08:53 PM
Lilliput did 800x600, now says no signal found fluffy2097 Input Devices 1 05-07-2007 03:04 PM
cool small vga card for lilliput and epia redzac LCD/Display 5 11-02-2004 06:18 AM
Lilliput with EPIA and linux bpierce815 General Hardware Discussion 1 09-03-2004 01:54 AM
FS: Opus PS, Lilliput + TS + Housing, Epia M10000. robutek Classified Archive 11 07-14-2004 02:21 PM
Sponsored Links
Ad Management by RedTyger
