Notices
Old 12-29-2007, 02:52 AM   #1
ID Code on MDT-X7000
Does anyone know how to turnoff the need to input the ID Code on the Xenarc?
Damn annoying every time it starts up.
allypally is offline   Reply With Quote
Old 01-20-2008, 07:02 PM   #2
Lost power
It shouldn't ask you for the id-code after the initial operation. The only time it will ask you again, is if you push the reset, or if it loses power completely (the 12vdc connector to the battery is disconnected, or the battery dies). I don't know how you are running power on it, but I'm guessing it's a theft deterant, so if someone rips the unit out of your car and they don't know the id-code it won't work (kinda silly since they already would have stole it).
tagmp is offline   Reply With Quote
Old 01-21-2008, 01:56 AM   #3
Thanks. Yes, currently got it working on the build bench while I setup the puter, so am cutting the power supply each time, which would explain it. Thanks for responding.
Old 01-21-2008, 05:04 PM   #4
No problem.
Weird Registration Code and Hardware Code problem lookinco StreetDeck 2 09-30-2006 03:25 AM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Head Unit 'code' - help! Laidback Car Audio 41 06-10-2005 09:53 AM
GPS/MapPoint VB Source Code stevieg Software & Software Development 4 06-08-2004 03:24 PM
