Notices
Old 12-29-2007, 04:17 AM   #1
copter's Avatar
8" 16:9 in Double Din GM Dash????
OK I've searched for hours and no luck. Has anyone installed an 8" 16:9 in a GM double din dash opening without hacking the dash? After looking at some pics there looks like there's an inch or so left over with a 7".
_____________________________
06 BLACKTIE LBZ | GRAYSTONE METALLIC | MBRP 4" | AMP STEPS | KMC DIESELS | TOYO M/T'S | NCT/COGNITO 4-6" | BILSTEIN 5100'S | MAG-HYTEC DIFF COVER | HID'S | PPE XCELLERTOR |
______________________________________
copter is offline   Reply With Quote
Old 12-29-2007, 09:33 AM   #2
FusionFanatic's Avatar
in that pic, it only has extra space on the side. it looks like it has no extra space at all on the top or bottom.
the screen size is measured diagonally from corner to opposite corner. an 8" screen is wider AND taller than a 7" screen. it's probably a little under 1/4" more at the top/bottom.
you'll probably lose some screen visibility on the top/bottom, but you may be able to adjust the monitor settings to correct that (however if you do that, it would defeat the purpose of using a bigger screen in the first place )
it looks like a 7" screen would fit best, but i would remove the LCD/touchscreen from the monitor housing so that all you see is the screen (not the plastic housing around it), it would look much cleaner that way.
good luck
FusionFanatic is offline   Reply With Quote
Old 12-29-2007, 07:43 PM   #3
The Vauxhall Vectra Project
ccsnet's Avatar
I have heard that you US GMs are 1.5 DIN.... may be I'm wrong. In Any case I'll be doing a Double DIN in my Vectra next year if thats any help ( Vauxhall = GM ).
Terran
ccsnet is offline   Reply With Quote
Old 01-02-2008, 07:52 PM   #4
I have the 8" widescreen and a GM. Now for the bad news... No.
First of all, your truck has the same size player as my car, GM "Din-and-a-half" or 1.5DIN
Look at sombody's stock import radio and you notice it's a bit taller, that's a Double DIN.
The way I mounted mine was by bending and painting an aluminum bracket so that the monitor is mounted just over the dash. Kindof like a fold out model but centered. I'll post pictures when I get them.
When you're looking at models remember that "Widescreen" monitors are much closer to 16:10 (even the Lilliput 889GL that says it's 16:9)
You can get get exact measurements of both the entire unit or the LCD only by doing a quick search of this site.
If you want a close way to figgure it out multiply the size of the monitor (eg. 8") by .86 for the width and by .52 for the height. This will give you the rough viewable size of the screen. The case size you'll have to look up.
What this all boils down to is that an 8" widescreen will not fit. A 7" widescreen also taller than 1.5 DIN, but only by a little bit. You may be able to get it to work if you have a little bit of room above or below inside the dash, but you will have to take the LCD out of the case for sure.
Hope this helps.
Ashley - http://www.nfspmotorsports.com
Check out my car club.
nfsp_trans_am is offline   Reply With Quote
Available Double Din Frame? fenderbender Fabrication 9 11-20-2008 10:48 PM
DIN and Double DIN Dimensions/Standards kubark42 General Hardware Discussion 14 11-17-2007 12:35 AM
5th Gen Camry - Double DIN (wider) for Single DIN H/U + also mounting options for 7" birdie Fabrication 1 09-01-2007 01:30 AM
2001 civic double din, posible? S_K_U_N_X Car Audio 2 08-19-2007 01:40 PM
2 Single DIN units in a Double DIN mount Dondro Newbie 5 06-22-2007 03:21 PM
