Old 01-23-2008, 12:06 AM   #1
700TSV annoying issue
OK so I have been noticing that every time I drive my car the usb portion of my 700tsv "goes out". I constantly hear the Usb plug in/ un plug notification noise, when u hear the noise the TS does not work, but when the noise repeats the TS starts to work. I checked the usb plug and everything is fine. I also check main connecting harness on the xenarc and it is connected nice and tight. Unfortunately the way my xenarc is molded I HAD to leave the back cover plate off.
I noticed the usb control module: CY-4W-USB-03. And If i jiggle with that the usb WORKS! I am wondering if i replace that board if it will work. But now on the CY-4W-USB-03there is a flat ribbon cable that im guessing goes to the TS controller panel and the other end of the CY4WUSCY-4W-USB-03B03 module there is a harness with 4 wires and it connects to the the main harness.
I came across this post
http://www.mp3car.com/vbulletin/inpu...-problems.html.
But on the lilliput the usb controller has solder connections, on the Xenarc the usb controller connects to the main harness via a 4pin cable.
Any input would be greatly appreciated!
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Bluetooth GPS connection issue - 1.1.0.0 Sinabl StreetDeck Bug Reports 5 12-14-2007 09:36 AM
Video Full Screen On/Off issue - 1.1.0.9 Kimota StreetDeck Bug Reports 1 12-12-2007 09:06 AM
Color Issues with Xenarc 700TSV BhashaZ LCD/Display 0 07-08-2007 11:37 PM
iGuidance Hibernation - Interesting Issue Troy McClure GPS 9 06-11-2005 02:16 AM
