The MP3car.com Store
Thread Tools Display Modes
Old 01-31-2008, 01:55 AM   #1
My Photos: (1)
Unhappy Xenarc Problems
Just bought a used 700TSV from the classifieds here. Plugged it into my laptop and a wall outlet. The power light comes on, stays solid for about 2-3 secs and starts blinking. There is no video, screen is completely black. Tried FN+f4, tried pressing the "S" button on the monitor, nothing. Tried it on my desktop computer and nothing there as well.
It looks like the warranty label is still on so i would assume the prev owner didn't open it. Anything I can do at this point to troubleshoot? Or am I SOL and need to ask for refund?
lazyboyw is offline   Reply With Quote
Sponsored Links
Old 01-31-2008, 05:36 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
What resolution are you feeding the Xenarc?
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-31-2008, 11:40 AM   #3
My Photos: (1)
Originally had it 1024x768, then turned it down to 800x600. Neither worked. I don't think the integrated video can do 800x480. But shouldn't the xenarc automatically shrink or stretch the resolution?
Old 01-31-2008, 02:32 PM   #4
JimmyFitz's CarPC Specs
JimmyFitz's Avatar
Vehicle: 2002 Thunderbird V8
My Photos: (0)
auto detect at power on
The Xenarc will look for a signal when first turned on. If it can't detect one, it will politely turn itself back off and never look again. It should show 800x600 with no problem. Check your connections and reboot. You can also try the RCA inputs to see if they work. Good luck.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 01-31-2008, 03:55 PM   #5
My Photos: (1)
Thanks for the reply, I will try that as soon as I get home from work.
Old 01-31-2008, 09:29 PM   #6
My Photos: (0)
It DOES continue looking for a signal. Unfortunately it's PAINFULLY slow for it to detect one. It takes like 5 to 10 seconds from the time I boot the computer to the time the screen comes on - so at first you might think it's not going to recognize it, but it will. You just have to be patient.
Stang70Fastback is offline   Reply With Quote
Old 01-31-2008, 11:03 PM   #7
My Photos: (1)
It works!
Thanks for the help guys. I talked to the prev owner and he said to try the car adapter cause he only tested the ac adapter for power. And it works great in the car.
I came back and took another look at the ac adapter and it said output 5v
He probably sent the wrong ac adapter by mistake. So just in case anyone run into this kind of thing in the future, make sure the ac plug is 12v output!
By the way, I think most xenarcs have voltage regulators built in so all those tests with a 5v source shouldn't damage the circuitry in the screen... should it?
Sponsored Links
vB code is On
Trackbacks are Off
warranty on lilliput and xenarc? flavor4real LCD/Display 0 10-17-2006 06:36 AM
Xenarc display problems redzed LCD/Display 8 09-03-2006 02:36 AM
xenarc problems puckhead LCD/Display 5 03-23-2006 06:38 PM
Xenarc issue with ATI AIW 9600Pro lookinco LCD/Display 1 09-23-2004 09:47 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 05:38 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
