I have one of these and they are pretty crappy. The stereo portion had terrible reception, the buttons would not work all the time, and the amplifier was weak and noisy. Also, the clock never worked right and now the little LCD only shows gibberish, if it shows anything at all. I hit it a few times and it blinked out (thankfully, as I do not no why it insisted on showing hours:minutes:seconds, not to mention that it could not keep time to save its life)
Within six months, the gears stripped and it is now a manual open and closed device, which is fine, as it works faster to pull it open than wait for the slow motor to laboriously open and close the screen. I glued a hinge to the back of the screen which stick out a little when it is closed to give me something to pull it open with, but closes behind the screen when open. I also put some Velcro on the dash and the monitor to hold it open when in use. Looks ugly when closed, but you cannot see it when in use.
The monitor itself is par with the rest of the non-transflective screens: hard to see in the daylight, but serviceable after adjusting the gamma, brightness, and contrast. The touchscreen portion works fine.
Eventually, I will remove the screen from the case and build it into my dash, as I no longer use the tuner for anything. Instead I have a separate amplifier and a Visteon HD radio tuner.
Good luck
