Old 02-06-2008, 03:10 PM   #1
sphere76 is an unknown quantity at this point
TM-868 backlight
Hi!
This might be too stupid question but...
I just bought an used 8" TFT (SGDQ TM-868).
It didnīt have AC/DC adapter so i bought a 12V, 1000mA adapter with + in center.
My problem is that when I turn it on, the screen stays black. Iīve tied almost everything but still..nothing. The power light is red. Shouldnīt it be green anyway?
Jari, Finland
sphere76 is offline   Reply With Quote
Old 02-06-2008, 04:07 PM   #2
Morpheus2010 is an unknown quantity at this point
mine just went out i have a shark 8" screen i bought from gooddeals18 it was working fine and it just went black. The wierd part is that the touchscreen still works when i touch any part of the screen my computer still responds. ie play, pause, next etc etc
Morpheus2010 is offline   Reply With Quote
Old 02-06-2008, 04:46 PM   #3
bbalazs is an unknown quantity at this point
That power seems to be quite low.
This type of monitor needs around 10W at normal working. Directly after switching on, the current runs above 2A for a short time (because charging capacitors), and perhaps your adapter is not strong enough to provide this, therefore voltage falls.
Run it from the PC power supply at home or
buy a cheap 12V 3A stabiliser IC (eg. 78T12) instead and drain the car battery (with engine on, of course).
bbalazs is offline   Reply With Quote
Old 02-06-2008, 04:48 PM   #4
Perhaps just the backlight is off. Try to enlight it by a strong source of light. Do you see any sign of picture? Use a picture with high contrast.
Old 02-08-2008, 06:50 PM   #5
All I see is when i turn it on is a flash and the screen stays black. i've even plugged it up to a ac adapter. The screen was working for a while before this happened. only the touchscreen works now. thanks for the help
TM 868 screen went dark elstev0 LCD/Display 0 08-15-2007 07:23 AM
tm 868 calibration YetiMan LCD/Display 1 04-23-2007 04:34 PM
tm 868 8 inch monitor and some other stuff sti robot Classified Archive 6 10-25-2006 11:53 AM
wtb ebay tm 868 touchscreen selmerguy Classified Archive 6 07-05-2006 05:30 PM
FS: 8" TM 868 recessed in 2000 Honda Accord (Ready to go) wu4607 Classified Archive 2 05-17-2006 01:32 AM
