Notices
Old 02-09-2008, 10:13 AM   #1
Not powering on
One day my DWW-700h just stopped working. No reason why.
When powered, the button backlight turns on. Now, it doesn't. I opened the screen up and tested good connectivity from the input wires all the way to the ribbon cable in the back of the screen. (see pics). I am testing with a 12v battery on my bench and a multimeter. The screen was powered off of my PSU. I do not see any signs of burnt transistors, no smell. I secured all other internal connections. Couldn't find any fuses.
Does anybody have any additional testing ideas? Thanks
Colossians 1:16 - Everything
vdog is offline   Reply With Quote
Old 02-09-2008, 01:18 PM   #2
That IC between grey wire and tip of your multimeter is a swiching regulator (I suppose LM2575 or so), measure the voltage on the pins. It produces 5V of 12V. Really?
I do not think, the panel does not have any fuse. Search component written F1 on the pcb. It perhaps does not seem to be a fuse. It sometimes looks like a green resistor or a small white brick, newest models are opaque plastic with small orange spot inside.
Have you got a photo of MUCH better quality of the panel?
bbalazs is offline   Reply With Quote
Old 02-10-2008, 04:29 PM   #3
bbalazs, thanks for your response. I found the problem. The ribbon cable towards the back of the unit was a little loose. I checked every connection except that one. Thanks again!
Noob question about powering speakers mozee Car Audio 0 04-16-2007 11:24 PM
Powering 7" touchscreen without SDC ironic Power Supplies 2 12-16-2005 08:24 AM
Advice on Powering my System st_claire Power Supplies 1 08-15-2005 03:15 PM
A solution for powering 12v stuff inside zootjeff Power Supplies 21 12-17-2004 07:21 PM
Powering a datalux screen from atx psu Speedpass101 Power Supplies 1 10-08-2004 04:19 AM
